Results 1 to 5 of 5
Thread: idle issue
    Default idle issue
    I have a 99 LS integra. The car idles just fine when I start it up. Once I hit the gas the idle will stick at 3500rpm. If I put my foot under the gas pedal and lift it up a bit, the rpms drop back to a normal 800 to 1000rpms. What causes this? It's very annoying. Do I need to clean the iacv? Thanks for any help
    Hwy 315
    sounds to me like your throttle body could use a little cleaning or your throttle cable is a tad too tight.
    Remove it and scrub it down with an old rag/toothbrush and a nice can of carb cleaner. Making sure to pay extra attention to where the butterfly plate comes in contact with the surrounding metal... it's probably just gummed itself up over the years.
    And when you're re-installing it, do not put extra tension on the throttle cable... it doesn't need to be tight like a banjo string - just snug enough so your throttle pedal doesn't have any extra play.
    - an easy problem to fix bro
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Quote Originally Posted by se7en
    -jonathan
    thats what i would do.
    Thats exactly what was needed!! Thanks se7en!! I really appreciate it
    when tensioning the cable you should have around 1/8" of deflection.
