Results 1 to 18 of 18
Thread: Weird shaking from brakes?
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Default Weird shaking from brakes?
    okay so i have slotted rotors in the front(dono if it has anything to to with this), but everytime i do HARD breaking, like a 40mph+ speed decrease, i get this strange feel through the pedal. I would describe it as the front pads rubbing something it shouldnt be Hard to explain... any insight?
    Save ur engines!
    Long Live GM! :^o
    Alpharetta
    Any sounds? Scrubbing, grinding...? Vibration? What type of pads are you using? Organic, Ceramic, Semi?
    Dec 2008
    Northside
    yea i had the same weird feeling wit my brakes, it turns out the axle nut came unless sum how but yea i tightend it and it works strait, i had to replace to whole rotor thas how much it was rubbing, anyways good luck
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Woodstock
    do you feel it through the steering wheel or the pedal? if it's the steering wheel that means your rotors are warped. and it being a slotted disk one cannot turn/machine those....
    Val RIP
    my only rule in life
    Newnan
    no reason for slotted rotors.. unless you have a real race car.
    learn to english
    Hates streched tires DunDunSkeert's Avatar
    Misawa, Aomori, Japan
    +1
    Also have you taken the time to bed in the pads properly?
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    Quote Originally Posted by ChuckNorris
    J.R
    Down South
    have this problem now...
    In the Fucking A
    I thought your dad owned or worked at a shop, why don't you ask him.
    I fucked Šhris's mom
    Fayco
    the rotors + pads came with the car when i bought it lol, so im not sure on the pad type. If i had to guess i would say organic.
    but i kno the rotors arnt warped, I know that feeling oh to well after driving/riding in cars my mom and/or sis drive.
    I feel the vibration through the pedal. I guess you could say it feels like something is rubbing on the brake pad/rotor that shouldnt be there. But what is throwing me off is the fact that it only happens under heavy braking.
    DunDunSkeert what does bed the pads mean?
    Save ur engines!
    ATL's Slow3st DSM!!! Ronsam2006's Avatar
    Quote Originally Posted by tdurr
    Just take the pads off and sand them smooth a little.
    Fayco
    wut grit sand paper? like 100-300
    Save ur engines!
    Get something in the 200-300 range and after that, if you have some, you can also sand it with something even smoother.
    I'd say use about 150 grit sand paper. Rub the brakepad on the sand paper in a figure 8 motion and don't inhale any of the dust. After you do this you should be in the bake pads like so. http://www.zeckhausen.com/bedding_in_brakes.htm
    Fayco
    ^^ thanks for the link, ill deff try this soon(prob once it warms up soon)
    Save ur engines!
    Kabul, Afghanistan.. Xrated O.G.'s Avatar
    Troubleville, USA
    Any particular reason as to why you can not machine them? I machine cross drilled and slotted rotors all the time. You do however need to be very mindfull when doing so....
    The XUV !!!
    Fayco
    ^^ details?
    Save ur engines!
    RE30
    my rack and pinion made weird noises like that before it got real bad. it started making noises that sounded like it came from the brakes or axles only under hard braking. after i checked it out, it was the rack and pinion. after a while it made real noticable noises nonstop.
