Results 1 to 16 of 16
Thread: ls turbo help
    Greene/Athens
    Question ls turbo help
    ok i jus bought a 89 crx si and im gona put a ls b18b1 motor in it and im planning on boosting it but i want it to be able to hold about 15 to 20 psi what all should i do this motor that would make it jus enough to handle that many pounds?????????
    get it sleeved and get pistons,rods, and head studs...oh and the main thing a good tune
    Greene/Athens
    how much would all that run me??
    Greene/Athens
    what if i put sum aftermarket cams and valve springs and retainers how much boost could i run then?
    1 million
    lol to get a block sleeved its around a 1000.
    Warner robins ,Ga
    heres Goinfasterthanu setup.
    Ls bottom end
    srp 8:5:1 pistons
    eagle rods
    acl bearings
    Ls head {THIS HEAD FLOWS}
    Fully ported { i have 1000$ just in head porting and such}
    5 angle valve job
    Arp head studs
    Crower retainers
    crower valve springs
    crower stage 2 cams
    msd wires and cap with coil
    powder coated valve cover vented with -10 an lines and spoolin catchcan
    aem fuel rail
    aem cam gears
    Turbo setup
    Revhard mani {a/c comatable}
    Garrett t3/4 turbo .60 trim
    2 1/2 inch down pipe
    Greddy profec b boost controller
    Hks bov
    Tial wastegate
    Big ASS intercooler
    Fluidyne rad
    Fal fan
    Hondata s200 with boost
    warner robins
    how much power do you want?????
    JJSPEC.COM
    Greene/Athens
    i was thinking about 275 300hp
    LS Resurrection
    Fulton County, Union City
    hell, if you dont got arp headstuds say good bye to your block
    Quote Originally Posted by joshk5145
    hell you can do that on a stock block LS if its healthy. if you want to be safe do block guard/pistons/rods build.
    Greene/Athens
    how much psi can i push with just a built head and arp headstuds
    warner robins
    you need to have a power goal that you want, not a psi goal...
    and dont waste your money on a block guard
    JJSPEC.COM
    Greene/Athens
    how much power u get out of that sohc red civic u got
    Greene/Athens
    warner robins
    ill be happy with 220 whp
    JJSPEC.COM
