Thread: 2007 DB-150 cc...
    IA Junior Member acura_dude's Avatar
    Dawsonville
    Default 2007 DB-150 cc...
    SOLD!
    Recieved this in a trade a while back. It a 2007 DB-150cc 4 stroke. Very fast with a lot of power! Doesn't look the best abd could use new plastics but that doesn't effect how it runs! Yes i know it is an off brand bike but it runs excellent and has tons of power and will easily pull a 200 pound man on a wheelie. Comes with extra set of plastics and has a brand new chain. Electric start does not work but starts on first kick!!!
    Asking $500 firm!!!
    call/text 404-933-8592
    email- [email protected]
    WEBSITE STATS .....
    DB-150 Specs:
    Max Speed:45+ MPH (Based on Load)Max Load:330 Lbs (150 Kg)Net Weight:231 Lbs (105 Kg)Power Plant:149cc 4-Stroke, Air-CooledMax Power:11.0 HP @ 6000 rpmTransmission:5-spd Manual w/ Reverse to ChainEngine Start:Kick onlyF/R Tire Size:70/100-19 & 90/100-16Brakes:Front / Rear Hydraulic DiscFront Suspensionual Telescoping ForksRear Suspension:Mono-Shock Swing-armFuel Capacity:1.50 GallonsOverall Dims:76x43x42"Wheelbase:51"Seat Height:32"Warranty:12-months, Limited Parts WarrantyAssembly:Comes 95% Assembled.Certifications:EPA / CARB approved.
    DB-150 Features:
    Wide handle bars with hand protectors for stability and control ...
    Telescoping front forks... mono-shock rear swing-arm
    Performance exhaust (sounds great and whole system has lots of power)...
    Superior construction with structural gusseting and quality welds...
    Standard US size 19" or 16" Spoke wheels with knobby tires.
    Sleek, Modern Body Plastic design in your choice of four colors.
    Poly fuel tank to avoid rusting.
    LIL WEAV
