Results 1 to 23 of 23
Thread: question before retune
    Default question before retune
    ok i was wondering if anyone could tell me what to check for before i go back to get my car retune. a ton of ppl have told me its something after the vtec kicks in. i have a drag mani and some crower 272 cams which ppl have said dont work together to well. but its gonna be a whole new setup this time. below is a picture of my last dyno sheet
    anybody?
    Southside Ridin HATCH
    SOOO what exactly are you asking.....
    maybe its leaning out fuel.. IDK
    roflcopter V-Spec II
    Norcross
    Who did the tune you posted up?
    turbos
    Id say the fuel and timing.
    looks like it just needs more fine tuning
    post ur whole set up
    TOO BIG
    ^^^^^this is what i was b18c1 darton open deck 85.5mm sleeves
    -crower crank makes it alomost a 2.2L
    -Custom Pauter rods
    -wiesco pistons 9:1 compression
    -arp head studs
    -cometic headgasket
    -01 gsr head
    -port and polished intake and exhaust side
    -Ferrera 1mm oversize valves
    -3angle valve job
    -crower dual valve springs
    -skunk2 titanium retainers
    -Crower stage 3 cams 272's
    -Aem cam gears...
    turbo kit
    turbonetics 50 trim
    450 injectors
    drag mani
    tial wastegate
    3 in dp
    Default hey
    here is a picture of my setup.i do have 1000cc injectors and a differentsetup im gonna use.just looking for a good turbo right now thats gonna hold up
    the county
    you still running the stock fuel pump?
    if you are i would get an upgrade to a walbro 255 or something. not real sure if thats right or whatever, but yea.
    i got a after market fuel pump.i thought if i didnt have one i would of only been close to 200whp
    Privateer Racing!!
    Duluth,Ga
    where is the air/fuel and a copy of the datalog?
    Default hey
    i never recieved either of those from scotty. what i posted is all he emailed to me.
    1000cc injectors are probably 3 times bigger then what ya need so thats not going to help your idle.
    That tune up top looks like garbage. I could sit in the garage and guess a better tune then that.
    What are you tuning with and who are you tuning with??
    Miss my Civic.
    Quote Originally Posted by kpowerhatch
    -Custom Pauter rods
    -arp head studs
    -cometic headgasket
    -01 gsr head
    -3angle valve job
    -Aem cam gears...
    turbo kit
    turbonetics 50 trim
    450 injectors
    drag mani
    tial wastegate
    3 in dp
    And you only made 250?!?!
    Are you asking why its so jumpy up top or why your not making shit for power?
    Warner robins ,Ga
    weird....i made 268whp/233tq 13-11lbs on my ls [8:5:1 c/r with stock head]
    Quote Originally Posted by Sentra
    lol both.alot of ppl are tellin me that a drag log mani and the cams dont work well together. but still on 10-12 psi i should of been at 300
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by B18c1Turboed
    x2. A/F is where it's at. Not a sheet showing your power.
    -Ant.
    The Carbon Fibered R6
    i ll try to see if i can get scotty to post it
    Privateer Racing!!
    Duluth,Ga
    When we get our dyno charts, it always has it at the bottom....
    ^^^who does your tuning
    Privateer Racing!!
    Duluth,Ga
    Ed at BAlance Performance!!! Best in GA!!
    he said the a/f was 12.0 to 12.5.
    af was 12-12.5 all the way across. for all you e-tuners out there. the reason for the choppy graph was because he didn't have a dump tube on the wg originally when we tuned it (along with 11ty billion other problems that we had to fix and no dump tube or way to fab one up at the time) and it was dumping right out into the compressor. hot non-oxygenated exhaust isn't so great for a turbo car.
    take my suggestions i gave you lamar and you'll be ok.
    thanks scotty you still did a good job cant wait to see what it does this next time
