Results 1 to 18 of 18
Thread: Wire tuck question!!! Bucky...I need some help
    Default Wire tuck question!!! Bucky...I need some help
    I want to relocate my battery to my trunk and my fuse box underneath my dash. What is normally the process in doing this? What do I use to lengthen the fuse box wires to make it long enough to go under the dash? If anyone could send me some pointers I would really appreciate it. Thanks in advance
    blank
    nowhere
    i usually dont cut anywires when i do my tucks. you will have to tuck everything to get the fuse box in there. the battery is easy to do
    Senior Member Nang's Avatar
    the fusebox you can unplug it from the bottom and then pull all the wires through the firewall
    J.R
    Down South
    I been wanting to do a tuck 2
    "nang" i've been talking with Paul and he said that you were def the one to talk to. We may have to meet up sometime if u wouldn't mind
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    is it just that easy to tuck the fuse box????? just unplug it and push the wires through the firewall and plug it all back in???? help me out also i got a 4dr 99 integra gsr
    Quote Originally Posted by b20vtecrr
    this was a dead as shit post.
    other hand ive need did a fuse box tuck. i have played with most of those wire and it does appear to be able to go back into the firewall.
    revolution big mac's Avatar
    If someone confirms this I'll do it tomorrow
    yea, unclip the bottom of the fuse box, then there should be like 5 plugs. unplug it, and pull the wires from the inside. ta da
    Quote Originally Posted by big mac
    have at it
    are the wires long enough to relocate into the glove box by any chance?
    PURP-a-trader PURP's Avatar
    They will reach without extending. As stated above.. Just unplug them. Push them through and then re-plug them back up.
    aight man that will be the first thing i do tomorrow morning. i just had to hear it from somebody that i knew might have done it. sorry to thread jack but when you relocate the battery is there a kit to do it? meaning wires and such
    get you about 10-12 feet of 8 gauge. and 15+ feet of 4 gauge. Then get a fuseless distribution block. with 2 in 1 out. I can go into further details if needed
    Southside Ridin HATCH
    ^Get some thick gauge wire, Forgot exact which size.. but yea get that for your battery relocation. auto parts store has it!
    you will have to solder them together and run one from trunk to starter then One from battery to ground somewere in your trunk (under carpet)
    sorry purp didnt see your post...
    fuseless distribution block? more details please?
    sorry to thread jack but ive bn wanting to do a battery conversion as well
    damn, i want that penis
    Your mom's bed
    Quote Originally Posted by marcos713
    google. works everytime
    http://willyfogg.com/se/p21082969/Bo...ibution+Block/
    http://www.deffaudio.com/store/produ...f96478b416386b
