Results 1 to 5 of 5
Thread: Looking for a little bit of metal work. - Not sure where this should go.
    Senior Member b18hb's Avatar
    Default Looking for a little bit of metal work. - Not sure where this should go.
    I'm working on a project for school, and I am in need of two of the same part. Essentially, it is 1/2" tubing bent on a 5" radius (to the center of the tube) spanning 180 degrees and cut to fit on a flat surface. Additionally, one hole will have to be drilled through both sides of the tube, and a few welds/ brazing/ any other metal to metal attachment method that can stand vibration for a decent length of time will need to be made.
    I'm looking for a shop or an individual who has the tools to do this with reasonable precision. Any recommendations? I can supply more detail if necessary.
    Also, I'm on the north east side of atlanta, and I'd prefer to stay local.
    Thanks a lot.
    Woodstock
    Find you a small welding/fab shop. If you are in the woodstock area there is this guy called "Crazy Dave" that has a place right off bells ferry that does great work for a damn good price.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Earth
    Quote Originally Posted by b18hb
    Thanks a lot.
    Do you need Mandrel bends? If so, that will cut your list down quite a bit...
    Damn, if you were about 1 and a half hours south, my school could do it for free.
    I appreciate the replies.
    I would prefer that the parts not have creases or any significant deformities when they're finished.
