Page 1 of 3 123 LastLast
Results 1 to 40 of 98
Thread: Highly Mod'ed Evo 8!!!
    Certified Gearhead sabastian458's Avatar
    Default Highly Mod'ed Evo 8!!!
    !!!SOLD!!!
    I have my 2003 Lancer Evolution 8 for sale, Apex silver, 62k miles, 12500 on Engine and transmission. 5 speed AWD for those that keep asking.
    NEW PIX!!! See posts 83-86.
    Those were taken on 2-17-09
    Quick run down of the car.
    The awsome:
    -2.3L stroker engine
    -AMS balance race balance shaft delete
    -Aries Forged race pistons- Rated to 44psi
    -Eagle Steel rods- Rate for 500-600 WHP
    -Eagle Forged crank- Rated at 900-1100 whp (proven power)
    -ARP main and head studs
    -bored, line honed, decked block
    -Brian Crower springs and retainers
    -Brian Crower 280 Intake and Exhaust camshafts
    -HKS or AEM adjustable silver camgears- cant remember which 1's- will look
    -Zaklee clear cam gear cover
    -Buschur Racing ported stock intake manifold
    -MILSPEC 65mm ported throttle body
    -Throttle body coolant bypass
    -AMS 1st GEN race intercooler with full hard piping (has AEM Air temp in it)
    -Custom Cold Air Preturbo intake piping 4in-3in-maf-K&N 4in filter
    -Evo 9 MR diverter valve with GUS mod- Holds 35+psi without leaks
    -HAFE exhaust manifold- cast stainless steel= no cracking!
    -HAFE O2 housing
    -Tial 44mm wastegate VTA- Silver
    -Garret GT3076R turbo- .83 turbine housing
    -Excedy twin disk clutch- HD unit
    -Custome 1 piece 3in exhaust- Megan downpipe, 3in piping, Magnaflow muff.
    -Intercooler piping heat wraped
    -A/c lines heat wraped
    -Upper rad hose heat wraped
    -Fuel line to rail heat wraped
    -Tial 44 discharge pipe heat wraped
    -Starter has DEI heat barrier blanket
    -Battery relocation to trunk
    -AMS's Walbro 255lp hp
    -HKS DLI-2 ignition box
    -Forge MBC- Silver
    -Mitsumoto? Slim radiator fan
    -FIC 950 cc injectors
    -Large bore fuel rail- supports upto 750ish WHP with pressure gauge
    -Perrin 25mm adjustable rear sway bar
    -Perrin rear stout mounts for sway bar
    -Custom fully adjustable rear sway bar endlinks
    -Rear upper strut bar
    -Stock Front upper strut bar
    -AMS Front, Cam, and transmission solid engine mounts
    -EBAY special rear solid mount
    -Shorter throw shifter with counter weighted knob
    -Solid shifter base bushings
    -Solid underhood shifter bushings
    -Evo 9 rear struts with TIEN lowering springs
    -Evo 8 front struts with TIEN lowering springs
    -Carbin fibre look alike Vortex genterator
    -2 Hella horns wired in with the 2 stock horns
    -Custom ECU tuning- 433WHP and 392 WTQ @ 27psi (I currently have it tuned for 31-30psi peak- 30-29 taper for a output of 456WHP & 421WTQ)
    -ECU has valet mode, flashing CEL for knock detection, set up for GM BCS boost control, and NO LIFT TO SHIFT mode. If you dont know what that is, you are missing out!
    The AEM A/F gauge and the Tetrix cable have been removed and sold, So I took it off the list. The Yoko's have been replaced with my other set of stock wheels and tires, only had about 10k miles on these.
    I know I have some other things done, but it is hard to remember them all. As I remember, I will update. The engine is capable of turning 8,000rpm's but I have a ECU rev limit set at 7600 and the shift light is set to luminate at 7400-7500. This car is a beast on the roads. Even with the good griping Yoko's, it is possible to spin all 4's in first, second and chirp 3rd. When launching the car, you have to ride the clutch slightly to keep the wheels from roasting. On 2-step, the engine is set to build 10psi. This car is easily a Vette, Cobra, or GTO killer. Easily. IF a race fuel tune is done on the car, you should be able to rund 35psi (but will be at the max of the turbo at the psi) and be able to break 500whp and be a 10sec street car. This set up is perfect for any auto crossing or street type racing.
    Now the not so perfect part:
    There are a few quater sized dings on the roof and hood. And there is a dent on the right quarter panel, Not too major, any painless dent repair guy should be able to fix. I just had the painless dent guy fix the quaterpanel. There is a scratch on the hood that will need to be touched up, and the under part of the rear bumper is scuffed. The brembos are doing the usual fading to brownbo's.
    The car looks completely stock from the outside except it being lowered. The factory spoiler had the clear start to fade, I had it fixed before any damage to the carbon fibre. The upper portion of the fibre is painted to match the car, the under portion and inner canards of the spoiler are still carbon fibre.
    Vid of the car:
    http://www.youtube.com/watch?v=4tXFrpICLLc
    http://www.youtube.com/watch?v=Szk9ss8e_Vs (crappy cell vid on these 2)
    PIX-Before the Battery relocation and custom cold air piping.
    There is a spark plug cover on the car now, but here is an underhood pic
    This is a pic from 1.5 years ago when the car was built. This shows how large the intercooler is.
    These are the pistons and rods in the engine
    This is the turbo currently on the car
    This is from 1.5 years ago when installing the engine, there isnt any gold now. It is all black.
    These next 1's are from the engine build from 1.5 years ago as well
    This is the comparison of the stock springs and retainers to the Brain Crower springs and retainers
    I easily have over $35,000 invested in this car. I bought the car 2 years ago for $20,000, and have since spent on parts alone an additional $10-15,000 plus if you wanted to add the labor I saved by either doing it myself, or paying a certified Mitsubishi Tech on the side for some of the labor, you can add another $3-5000.
    Now I know that I will not be able to recoup all of my money, I know this. I am sad not be able to, but with the Carpolcolypse that we are in, it just is not possible. The last Evo 8 to be retailed in my town was sold for $25,000 and it was a yellow stock Evo. Kelly Blue Book's Suggested Retail price of a STOCK Evo 8 is $19,600- http://www.kbb.com/KBB/UsedCars/Pric...rivate%20Party
    I am willing to sell for 2nd price drop from $20,000 to $17,500 FIRM. Cash talks, bull shit walks. I know how much my Evo is worth, so low ballers need to keep looking somewhere else. I dont HAVE to sell but want to. I am motivated to sell the car, I DO NOT WANT TRADES I dont like checks (bank checks PM me about), money orders (unless certified), paypal (Unless it is for a deposit and you include the Fee), or bitchy wives/girlfriends (no exception here). No children or animals either I am in the process of trying to payoff the last bit of my loan on the car. I can disclose the lendor to any serious buyer if need be.
    You can text/call me at 864-304-3328.
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    WOW......love it.......now I need 20k.
    You should be able to get a loan for the majority of the ammount.
    Kennesaw, GA
    What year is it?
    2003 with 62k miles. I forgot to put that in there. sorry
    Lunch Bump! Motivated to sell! Gotta pick my vette up this coming week!
    afternoon bump!
    Bump! This weekend only! $$$18,000!!!!!!!
    Bump!! Come on people, I know someone out there wants a fast ass hell Evo! 10sec 1/4 mile car here.
    i like how it looks pretty much stock. good luck.
    Quote Originally Posted by DeeAOne
    I have been able to surprise more than a few people with this car. Even tho the car cams hard, people still under estimate it.
    homie dont play that
    wow good shit bump for u
    ....True ////OFFSET\\\\
    villa rica, ga
    very nice and gl on getting your vette......not sure which one i'd rather have considering the power of your car but the vettes are nice
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    doubt you will say yes, but would you take payments?
    You know whats faster than light? Darkness, now thats fast my friend. Never let a dream remain a dream, no matter how surreal.
    Woodstock
    Uhh is this Alex's car? I recognize that front bumper.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Sorry, im not a bank
    And no this is not Alex's car. I dont know alex. The bumper is from any stock 03-05 Evolution, so there are going to be a few just like it out there
    Bump! Need to sell soon! I would rather someone who knows what these cars are, and can take care of it instead of taking it to a dealer and selling it.
    Bump! Going away 1 way or another in the next 2 days! Priced to MOVE!!
    BUMP!! $18000 IS STILL UP!
    PRICE DROP!! $17,000!!!
    Unknown
    where is dis car located ... is it automatic
    Unknown
    where is dis car located ... is it automatic ????????
    Quote Originally Posted by Darkmeskin
    LOLOLOLOL
    It is in easley SC 1.5 hours from ATL. No it is not an automatic, This is and EVOLUTION!!! only come in manual transmission until the 10 model year, this is the 8th
    Morning Bump! $17,000
    TTT!!!
    I heart fat girls tinkolby_25's Avatar
    Jacksonville/Centre, AL
    who did the tuning? those are kinda low numbers for a gt30, my 03 made 425whp at 24psi and i had way less bolt ons and stock internals
    no that isnt low numbers for a gt30 on pump 93 (10%ethanol) That is pretty good numbers. The other Evo arround here that had a similar set up neted less power than I but had the same stroker, turbo, manifold set up and he had more aggressive cams.
    Quote Originally Posted by tinkolby_25
    it also depends on what dyno you were at too. some dynos favor others by upto 25+ whp/wtq
    Bump! Need to sell!
    BUMP!!!
    BUMP!!
    mine made 425 on a mustang dyno with straight 93 on 24 psi and hks 272 cams...but I am interested in this
    if it was an 04 it would already be at my house lol
    bump for a HOT CAR!!!
    there is not a difference between the 03 and 04 evo 8's
    And my top let back never_finished's Avatar
    Oct 2003
    8k
    damn...i want this. someone needs to buy mine asap!
    yah I know know...I know a whole lot about evos
    my bank just wants me to get 04 an up...pm me the least you would take and maybe we can work somethin out so I can take it off your handslol
    AG Member
    I-20 West.
    pm'ed
    are you serious? best I will take? IT IS $17,000 You are not going to find better than that, especially with as much money poured under the hood. Sorry. $17,000 is the lowest
    ~~I Like the ****~~
    Not trying to say your price is not cheap b/c it is but ct9agsr is selling his 700+whp evo for not much more =P.
    My current vehicles
    04 A4 GTO
    02 A Camry
