Thread: Water pump leak?...
    Norcross
    Default Water pump leak?...
    Lately my antifreeze has been leaking from somewhere around my timing belt. I can see antifreeze sorta splashing up, but this only happens sometimes. I checked all my hoses n they're ok, so im guessing i need to replace my water pump? reps for help
    Senior Member G.C's Avatar
    Forgot
    look at it. I remember when my water pump busted, it was leaking from the hole on the water pump. You can see on the water pump too, if it leaked or not. There should be some kind of mark left on it like rust looking.
    :idb:
    athens
    im pretty sure therell b a rubber gasket kinda thing for th pump..chek to see it tht isnt comletely gone. tht could cause a leak..visual inspection ftw. turn th car on pop th hood and look arnd..may be rev th engine..with safety glasses on
    Norcross
    anyone know of a good shop where i could get my water pump changed
    step sticky stephen's Avatar
    check with some of the site sponsors. you can also hit up vteckidd.
    you should also get a new timing belt while you're at it.
    Norcross
    Quote Originally Posted by stephen
    koo thanks.. i read online that i should replace the tensioner and cam seal also? is it necessary?
    Forgot
    Sam can do that for you. Belt/Pump/tensioner for 100$.
    :idb:
    Norcross
    call him for me haha
    smalls get a water pump timing belt cam seals front main seal all new driver belts (if they havent been replaced in awhile) and a tensioner. save yourself the money now from having to do it again later on. an hell if your motor is high mileage u might want to throw in a oil pump also.
