Thread: Competition clutch OEM pressure plate?
    Default Competition clutch OEM pressure plate?
    Just received my competition clutch ironman for an AP1 s2k and the pressure plate is the same as my OEM but in black?? Setup looks legit but does competition clutch use the OEM stuff and just harden it?? Thanks for any insight on this.
    How do you know its the same? Did you check the pressure of the pressure plate and compare them?
    I haven't checked anything that has to do with the pressure plate. I have both of them here infront of me and they have the exact markings both are stamped with "Honda" and have the same numbes stamped on them. I am assuming they just used the oem pp and hardened it as act exedy and other companies do.
    Quote Originally Posted by RX4BRDM
    I can't say for sure because I haven't dealt with any of their foreign stuff, but typically they'll use the same hat and put a different diaphram in them. This may or may not be the case. I've seen the oem replacements or "stage 1" as some call them, have a little bit stiffer pressure plate, and an organic disc. If you have any specific questions, I would call them and find out exactly what it is.
    Either way, most of the hats are the same, regardless of which clutch. They just have different diaphrams in them, which is where you get your clamping force.
    D0 W3RK RedEj8's Avatar
    Macon
    Yep. Many clutch manufacturers use the oem hat and just heat treat the diaphragm for more pressure. A good example would be any clutch for a 86-92 Supra. Well except custom multi-plate clutches.
    Only way you will be able to tell is take the clutch to someone who can test it..which would usually be a clutch manufacturer.
    Thanks guys.
