Thread: car is rocky / bumpy at low speeds
    soon to be fast
    Default car is rocky / bumpy at low speeds
    any ideas.
    i think it might be a bent rim.
    was reading up and it could possible be lots of other things.
    gonna see tomorrow. >.<
    or maybe just inbalance of tires due to the front two balding.
    Senior Member Schugg's Avatar
    probably little chance of this being it but i seen a guy riding with loose lug nuts on one tire once, when he was going slow it was bouncing around alot, like it was going to fall off, then when he sped up it smoothed out. i tried to pull up beside him and tell him but he was old and foreign and just looked at me like i was a retard or i was assaulting him and rolled his window up.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    athens
    wow..somebody who finally did some hw on their own. reps for u.
    research ftw
    roberta
    the inner chord on the tire could have snapped
    soon to be fast
    Quote Originally Posted by jcs
    that's interesting. never heard of that. care to explain?
    Turbo-Wired
    East Cobb
    The steel/polyester/nylon/rayon plies of the radial belt can break, causing them to separate. This causes lumps in the tire and eventually spreads across the whole tire as the stress from the separated belts cause other belts to break.
    Anyways, a brief and simple rule of thumb is: Most Vibrations between 40-55 are caused by imbalance that has to do with the weights of the tire being off, and can be fixed by a balancing machine. Vibrations that are more severe above 55 than in the 45-55 range are caused by Road Force, which is the tire assembly being overall out of round. This can be because of a bad tire or a bent wheel, or both. This can be measured by a newer balance with road force measuring and can sometimes be fixed by Indexing the tire to the wheel, so that they make a better assembly overall. Doesn't always work. Low-speed vibrations are often caused by something being loose in the suspension.
    My suggestion? As soon as possible check every bolt for tightness, could be a number of things, not the least of which is the already suggested loose lugnuts. Could be a bad tire too though.
    roberta
    Quote Originally Posted by osiriskidd
    ^^he just did.lol
    soon to be fast
    Quote Originally Posted by Kaiser
    awesome thanks.
    LS Resurrection
    Fulton County, Union City
    tie bar?
