Results 1 to 5 of 5
Thread: Cold Stutter: ECU throws 9 and 15
    Default Cold Stutter: ECU throws 9 and 15
    I have a 93 Integra with a B20B @ 60k.
    It stutters around 2-3.5 RPM during the cold, so bad it stalls out when I shift sometimes.
    I had to replace the check engine bulb and tested it, it throws error code 9 which is No.1 Cylinder Position, or the CYP sensor most likely located in the distributor.
    It also throws 15 which is the Ignition Output Signal, also located in the distributor?
    I dunno do I need to replace the whole dizzy or can i get a sensor somewhere or an igniter or what?
    If I do need a distributor wheres a good place to get affordable/reliable.
    SwiperNoSwiping!!
    Go ahead and replace the entire dizzy because you have 2 sensors that aren't acting right that are both located in the distributor. i had this same trouble with the CKP sensor (also located in the distributor) yesterday and replacing the distributor solved the issue.... I got mine from Napa.
    u remind me of a wigger !
    you can replace just the sensor, but its easier for most to just replace the whole thing..
    Thanks guys. Gonna get on that.
    Will a regular B18b/B17 distributor work for a b20b?
    One Curve At A Time
    If its not the dizzy, check spark plugs. My car did that when i had bad spark plugs.
    97 DX Civic w/ H22 FS
