Thread: sp sensor alternator fuse blow out HELP!!!
    VTAK YO!!! GAsHONDABOI's Avatar
    SEVENohSIX
    Default sp sensor alternator fuse blow out HELP!!!
    OK, I have 98 GSR. For some damn reson I keep blowing the 7.5A Alternator SP Sensor fuse. If I change the fuse and just turn the key with out starting the car sometimes it blows. I can crank the car and it will run perfect. But fuse will blow other time when i get 4 or so miles down the road. I can swap fuses and no codes till I try to drive it again. Any ideas ??? An what the hell is doing this???
    if you have any advice please let me know pm or call me 706 691 8345 i thank you in advance
    check your 02 sensor wires, make sure they arent melted to something or together, had this issue in a customers car....
    SEVENohSIX
    Default o2
    thank you id try it tonite but its 14 degrees outside so ill eskmo up tomorrow and try that thanks alot let me know if you think ofanything else
    Southside
    x2
    SEVENohSIX
    Quote Originally Posted by EJ1soSlo
    x2
    X#3 thats exactly what it was it was the second o2 sensor plug a wire snapped from my cat i think its cause i got my exhaust custom tucked so i could keep my car lower 18 dollars in fuses for one wire ... but its fixed now thank you
    you are welcome.
