Thread: boost problem.........-
    you dont need to know
    Default boost problem.........-
    long story short , i have a 7 pound wastgate on a t3/t4 it almost boostes 4lb every day and every now and then 7lb , will a bad turbo cause it not to boost right , i have no boost leaks any where , and it will boost 7lb in high rpms 3rd and 4th gear , if any one has had this probelm , lmk and it is on a 91 crx si sohc. thanks.
    f*ck off
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    so u old get to 7 psi every now and then. a bad turbo would cause that. like if u have bent on missing fins, loosed compressor or exhaust housing. or if u think u have a 7 pound wastegate and u actually have a 4 pound wastegate and now that its cold ur creeping to 7 psi.
    thanks.
    f*ck off
    dc5
    ATL, GA
    do a datalog with hondata and check it out
    Sounds like a 4 pound spring creeping as posted above....
    2009 zx10R
    2005 919
    2006 xt225 dual sport
