Results 1 to 10 of 10
Thread: I Have a Distributor Question, need help asap
    SwiperNoSwiping!!
    Thumbs down I Have a Distributor Question, need help asap
    I have 2 OBD0 B-seris distributors, one of them is for engines with vtec, and the other is for engines with non-vtec. Just so happens that the non-vtec distributor that i have has a bad CKP Sensor in it (crank position) and what i was wondering is, if the internals/CKP from the vtec dizzy would work with the non-vtec distributor with the bad CKP sensor?
    u remind me of a wigger !
    SwiperNoSwiping!!
    or can i just cut off one of the mounting spots on the vtec distributor and bolt it up?
    Yes the modules an coils will interchange
    SwiperNoSwiping!!
    Wait, so i CAN take the crank position sensor out of the vtec dizzy, and re-install it in the non-vtec one, and have it work correctly?
    yes what tech 5 said.
    SwiperNoSwiping!!
    Okay.... Now, what if i wanted to just plug the vtec dizzy into the non-vtec harness as-is, would i be able to do that?
    guts are the same
    yup it will work.
    Road Race Junkie rogue55's Avatar
    Oct 2003
    Cumming-Gainesville
    You could just take all the parts out of the inside of the vtec dizzy, and install them in the other housing. That way, it all bolts up nice too.
    Anyone can drive fast in a straight line. I want to carve corners.
    Red 94 Civic #55
    National Auto Sport Association
    HPDE Driver and Corner Worker
    Working my way up to the Honda Challenge Series
    nasaproracing.com
    nasa-se.com
    hondachallenge.com
    SwiperNoSwiping!!
    Okay...well, i bought a new dizzy and installed it in the car today, same issue...
    The circuit for my CKP is somehow screwed up, and has been shorted out. Now, its gone from the car not running correctly, to the car not running at all. Idk What happened...
