So my daily driver is acting up on me.
Started on Tuesday. I went to shift into second and couldn't, slowed down and tried to shift back into first and couldn't get back into first. I turned off the truck and re started it and it drove fine for about 5 minutes, then did same thing.
I started it 2 hours later and it drove home fine, only to make a chirping noise upon entering every gear (but this didnt start till I was almost home). Now it will drive fine but after a little while of driving, it makes a noise resembling a turkey call when you put from truck neutral into the next gear. Not while coming out of a gear though. Also makes chirping noise when in first gear and clutch pedal is pressed all the way...
I'm thinking wither one of three things.
1. Input shaft bearing
2. Throw out Bearing
3. Slave Cylinder
Any help on this would be amazing, and thanks in advance IA.
