Thread: oil drain ?
    AKA THE BROWN MAN
    Kennesaw, Georgia, United States
    Default oil drain ?
    im installing a turbo setup on my 99 y8 and i have an idea on how to setup the oil drain/dump tube i was just wonderin if anyone had any suggestion on din this little hurrdle in this processreps will given to all who help oh yeah if you got any good pictures of what it looks like before install and after install that would be great im better with pictures thanks for looking
    Ohio asshole.
    Lots of people do a AN setup so it threads on the turbo and the oil pan.
    Me, I just use a piece of rubber hose. I took an old shift linkage, cut it, drilled a hole, and welded it on. It was very simple, quick, and works just fine.
    Sorry I have no pics, but I did weld it in a way that my hose is only 2" long.
    AKA THE BROWN MAN
    how did u weld it to your pan bein that its cast aluminum or did u get someone to do it for u if so how much they charge u for it
    Ohio asshole.
    I'm running a B20 therefore my pan is steel. It's actually the pan I had on my B16 before I changed to the B20.
    You can't weld steel to aluminum anyways.
    warner robins
    if you dont want to weld the pan you can use a bulkhead fitting
    http://store.summitracing.com/partde...5&autoview=sku
    JJSPEC.COM
    Dead or alive WANTED's Avatar
    ^ You beat me to it. The only disadvantage to this is that if you're not spot on, they have tendancy to leak a little. Otherwise, they work just fine for not being welded on.
    "Horsepower is no substitute for brains, fuckers."
    AKA THE BROWN MAN
    so just gotta find the correct size drill and tap. then throw it in with some tephlon tape i think thats how u spell it lol
    and get an AN -10 line to drain the oil
    make sure u put it at the top of ur pan not in the middle or the bottom like ive seen several times and had to redo.
    AKA THE BROWN MAN
    thanks for all the help guys
