Thread: crower stage 3 cams
    Default crower stage 3 cams
    im tryin to figure out if my crower stage 3 cams are all motor or if there turbo cams. on there website it says stage 3 cams are all motor cams
    Ohio asshole.
    They'll be used more for all motor, however ANY cam upgrade is going to be better for boost. The more you let the motor breathe, the quicker it will spool.
    Those cams will work well for a boosted motor (i'm running them in my B20). I have compared them with stock, and I like the stage 3's better.
    Senior Member G.C's Avatar
    Forgot
    Of course its going to be better than stock.lol
    The point is, if you have the money. You can't just drop a cam in there and call it a day.
    :idb:
    Alpharetta, Ga
    just because you have aftermarket cams doesnt mean they are better for boost. and just because it can breathe better for NA doesnt mean it will be better for turbo... just because you can get more air volume wise doesnt mean you have the velocity to make power.. and a lot of stock cams are better for boost anyways.
    The G Spot Hero
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Quote Originally Posted by Dirty Mech.
    bingo.
    a lot of cams optimized for N/A power have a lot of overlap to make use of the scavenging effect. this equates to intake charge just being wasted on a boosted setup. that, among other things, is the reason for different cam profiles on a set optimized for boost or nitrous vs. N/A.
    Who knows?
    JDM TYTE AnthonyF's Avatar
    If you do cams, invest in another head. Take the head to DOVER heads, get good valves, head worked a bit, etc... So when you get that head all good and ready, all you have to do is swap it over with no real down time of your car.
    -At.
    The Carbon Fibered R6
    Alpharetta, Ga
    -At.
    or you know get a sceond long block and build that.
    The G Spot Hero
