Results 1 to 39 of 39
Thread: 2010 Lexus HS 250h
    Everywhere
    Default 2010 Lexus HS 250h
    Vossen CV3 20x9 & 20x10.5
    Everywhere
    Lexus Stages World Debut of the 2010 HS 250h - the World’s First Dedicated Luxury Hybrid - at the North American International Auto Show in Detroit
    DETROIT (Jan. 11, 2009) – Lexus today revealed the 2010 HS 250h, the world’s first dedicated luxury hybrid vehicle, at the North American International Auto Show. The HS 250h will be Lexus’ fourth hybrid and the most fuel-efficient vehicle in its lineup. It also will be the first Lexus to utilize carbon-neutral Ecological Plastic materials in a new futuristic cockpit and interior design.
    A welcomed addition to Lexus’ entry-luxury sedan lineup, the HS 250h fits nicely between the IS luxury sport sedan and the ES luxury sedan. Research has shown that more than 60 percent of entry-luxury car buyers would have considered a hybrid if available, and the HS will provide these consumers with a viable purchase option.
    Equipped with Lexus’ first four-cylinder gas engine, the 2.4-liter Atkinson-cycle powerplant is part of the latest Lexus Hybrid Drive System, which generates 187 total system horsepower. The highly efficient Atkinson-cycle engine, made possible by the Variable Valve Timing with intelligence (VVT-i) system, allows the expansion/power stroke to be longer than the compression stroke so that combustion energy can be more effectively used for production of engine power. The HS 250h sedan’s expected fuel efficiency will be more than 30-percent better than the most fuel-efficient model currently in the Lexus lineup, while earning a SULEV emissions rating utilizing regular 87-octane gasoline. Among the technologies adopted in the 2.4-liter four-cylinder engine are cooling piston oil jets; an optimized balance shaft rate for improved Noise, Vibration and Harshness (NVH) characteristics; and a hot-air venting system mounted behind the radiator.
    Like the all-new 2010 RX 450h hybrid utility vehicle that made its debut in November, the HS 250h will include a new system designed to improve efficiency. The exhaust heat recovery system reduces engine warm-up time, thus allowing it to stop earlier, more often, and for longer periods. A windshield with infrared-ray (IR) reduction properties, which helps keep the interior more cool, has been adopted in order to decrease the amount of air conditioning needed to lower the cabin temperature. In addition to the exhaust heat recovery system and the IR windshield, available power-saving LED headlamps also contribute to improved fuel efficiency and emissions.
    The all-new HS 250h sedan’s 0.27 drag coefficient (Cd) makes it among the most aerodynamic in its class. Airflow management over the exterior, below the under floor and through the air passages was extensively examined. A unique gull-wing-shaped roof-panel design reduces mass and overall vehicle height, thus reducing drag and improving fuel efficiency. The front spoiler, rear spoiler, rear under spoiler, and diffuser fins all reduce turbulence. Smooth A-pillar shape and the optimized angle and curvature of the bumper side panels also reduce wake turbulence, as does the increased taper of the fender side panels. The under-floor covers have been optimally positioned for reduced drag, while airflow restriction in the engine compartment has been lowered by optimizing the air-duct profiles around the radiator.
    Aerodynamic design has also contributed to decreased wind noise. A smoother transition between windshield (complete with a sound-insulating inner layer) and roof line has improved air flow and reduced turbulence.
    As is appropriate for the first dedicated luxury hybrid vehicle, the HS 250h includes proactive adoption of plant-based, carbon-neutral “Ecological Plastics” or bio-plastics in specific interior areas. Ecological Plastic emits less carbon dioxide during a product’s lifecycle than plastic made solely from petroleum. Among the areas of utilization will be an industry-first use in luggage-trim upholstery. Other areas are the cowl-side trim, door scuff plate, tool box area, floor-finish plate, seat cushions, and the package tray behind the rear seats. Overall, approximately 30-percent of the interior and luggage area is covered with Ecological Plastic. Over the estimated lifecycle of the vehicle, the HS 250h will have approximately 20-percent fewer carbon-dioxide emissions as a result of utilizing the Ecological Plastic trim pieces.
    Like all Lexus hybrid models, significant time was spent in developing the HS 250h with optimized NVH characteristics. Dynamic dampers at each engine-mounting point reduce noise and vibration, resonators improve intake air noise, and optimized exhaust flow reduces exhaust sound. Special coatings dampen both engine and road noise, while improved seals around doors, hood and fenders reduce wind-noise penetration into the cabin. Vibration has been reduced by improving the shape and thickness of the suspension-mounting points. In addition, power-window speed controllers have been adopted from the LS luxury sedan, which insure a slower, soft closing rate.
    The HS 250h chassis design provides an outstanding ride and comfort with the decreased NVH required by a Lexus hybrid. The MacPherson strut front suspension is designed to achieve both straight-line and braking control, and a positive steering feel. A double-wishbone rear suspension provides excellent maneuverability, control and comfort with a low spring mount that contributes to better packaging and superior cargo space. Coil springs, anti-roll bars and shock-absorber rebound springs are utilized front and rear. The HS 250h will have uniquely designed standard 17- and optional 18-inch wheels.
    The rack-and-pinion steering system utilizes a brushless Electric Power Steering (EPS) motor on the steering column, which provides improved steering feel, a reduction in harsh feedback, and better emissions by not draining engine power like conventional hydraulic systems.
    The EPS is an integral part of an available lane keep assist system, a new driver assist that adds smooth steering torque to help the vehicle stay in the center of the lane. The amount of assisted torque is dependant on a lane-marker detection camera. It includes a lane departure warning feature that is designed to detect possible lane departure; it then gives the driver an audible warning and provides feedback via the steering wheel to encourage corrective action.
    The HS is slightly longer than the IS and is taller than both the IS and ES. It also has a greater couple distance (distance hip to hip between front and rear passengers) than any other vehicle in its class other than the ES. The contoured front-seat backs also add to increased rear-seat legroom.
    The HS features a unique advanced cockpit and an interior design that emphasizes innovation and craftsmanship. The uniquely stylish cabin has standard leather-trim seats, a moonroof, Lexus premium audio systems, and a new standard multi-media package. The media features include Bluetooth® technology, integrated satellite radio (subscription required), voice recognition, and USB iPod connectivity controlled via steering-wheel controls or a display screen. A high-contrast multi-information display, located in the instrument panel’s hybrid system indicator gauge, is controlled via steering-wheel-mounted controls, allowing the driver to easily control various functions and information.
    Another key element of the modern interior is Lexus’ new available Hard Disk Drive (HDD) Navigation System, which features a retractable navigation screen that is positioned well back and up front in the dash. The positioning helps improve visibility and reduce driver eye movement. Similar to the new RX, the HS system features the all-new “Remote Touch” controller that is both intuitive and ergonomic and allows for easy use of the Navigation System. The controller is positioned on the center console and is as natural to the driver’s hand as a computer mouse. It can also be customized to the desired level of haptic feedback.
    The Navigation System also includes a new casual-speech voice recognition feature. This allows drivers to give more flexible, conversational commands for easier access and control of the audio, climate and navigation functions. Also included are XM® NavTraffic® and NavWeatherTM, along with XM Sports and Stock information.
    Also helping to reduce driver eye movement is an optional Heads-up Display (HUD). The HUD uses high-intensity LEDs to make the display bright enough to be read even in direct sunlight.
    A class-leading 10 airbags will be standard on the all-new HS 250h as well as active front head rests, which help passengers in case of certain types of rear-end accidents. The HS also will feature Lexus’ Vehicle Stability Control (VSC) system and optional Pre-Collision System with Dynamic Radar Cruise Control.
    An available wide-view front monitor helps the driver to check hard-to-see areas. Using a camera mounted in the front grille, the monitor provides a 190-degree front view on the Navigation screen with the push of a button on the steering wheel.
    The HS 250h will also offer Lexus’ next generation telematics systems, Lexus Enform and Safety Connect. Safety Connect will provide automatic collision notification, stolen vehicle location, 24/7 emergency and roadside assistance.
    Lexus Enform’s Destination Assist features operators who will help drivers look up points of interest such as shopping centers or other business locations like Zagat-rated restaurants, and then wirelessly send directions directly to the vehicle’s navigation system.
    Lexus Enform’s eDestination service will allow customers to pull up multiple points of interest on any computer and send them directly to the car’s navigation system. This innovative new feature will allow drivers to send a total of 200 destinations at a time to their vehicles.
    The all-new 2010 HS 250h will reach dealerships nationwide in late summer.
    2010 HS 250h PRELIMINARY SPECIFICATIONS
    Total Hybrid System Horsepower 187 hp
    Engine 2.4-liter 4-cylinder
    Transmission Transmission Electronically
    Controlled Continuously
    Variable Transmission
    Seating Capacity 5
    Width (inches) 70.3
    Height (inches) 59.3
    Overall Length (inches) 184.8
    Wheelbase (inches) 106.3
    Driven Wheels FWD
    Wheels 17x7.0
    w/ P215/55R17
    or
    18x7.5
    w/ P225/45R18
    (Optional)
    Emissions Rating SULEV
    WTFUDGE IS THIS!!!?? A PRIUS RETARDED BABY THAT ONE DAY AT THE DESIGNER TEAM CHRISTMAS PARTY EVERYONE WAS SO DRUNK THAT DECIDED HEY LETS MAKE A LUXURY HYBRID!!!!???
    who's f*#kin oreo's! stubbyda91's Avatar
    Buchanan
    looks like the new civic 4 door lol
    looks ok
    1991 Acura Integra
    1998 Toyota Corolla
    Dunwoody
    looks like a new civic and a prius.
    FAIL.
    802 of 1010 Thrust's Avatar
    Atl
    Basically its just a re-badged prius.
    04 Terminator
    Funk E. Fresh okra1981's Avatar
    West
    Looks kind of like the new Corolla, except that awkward looking mouse thing on the dash. I took too long trying to compare the dimensions to the Corolla and Camry to figure out what platform this was based off of, I'm still not sure though, at least this car looks good.
    Some say that his politics are terrifying, and that he once punched a horse to the ground...
    Everywhere
    Quote Originally Posted by Thrust
    Actually its not. Uses a 2.4 engine not the 1.6. This also have an idependent rear suspension, the Prius does not. The engines and exteriors don't share one panel. The Prius is a hatchback, the Lexus is a sedan.
    Do they share some parts? Yup. Its not a rebadge though.
    IA's culinary pro TheGrillMan's Avatar
    gross
    G-nett.
    looks like a fat Camry to me.
    Mischief.tv blown lsj's Avatar
    Neat, looks 100x better than a prius.
    1 of 1,165 Black SS/SC's made in 2006
    LSJ!!
    Senior Member G.C's Avatar
    Forgot
    agree^^
    :idb:
    sandy springs
    30k+ corolla
    ಠ_ಠ Kamikaze's Avatar
    Fulton Co.
    Yeah looks like a loaded Corolla.
    Dunwoody
    the more i look at it the cheaper it looks.
    ALL CAPS JITB's Avatar
    toyota thinks its slick...tryin to justify releasing a 30k hybrid corolla!
    Never go full retard
    Nashville
    Sweet camry
    Nasty
    Stone Mountain
    if the new civic butt raped a corolla and a camery, this is wat the result would be. pure ass
    It looks like a Ford Focus + Subaru Impreza with Lexus IS details. I guess it's all for aerodynamic functionality, but really...Lexus makes MUCH better looking cars than this.
    __DailyGrind
    ewwwwwwwwwwww ... looks like a Toyota Corolla
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    i don't thing my mum would even like this
    Certified Gearhead neon_guy's Avatar
    I like it more the first time it came out...in like 07...when it didn't cost 60k...and it was called a Carolla.
    Pssssssft!!!! Zoom Zoom BOOM!!!!
    Low-n-Slow iEvo's Avatar
    Gnett
    it will sell........its a lexus
    LOOKS LIKE LEXUS' COROLLA
    1010011010 Atlblkz06's Avatar
    Hell
    Quote Originally Posted by 1SICKLEX
    Its a rebadged Camry Hybrid drivetrain, with a prius shifter and a "Lexus" body...
    The Hybrid system seems to be somewhat improved - but hardly enough to call it a new car.
    Long Live GM! :^o
    Alpharetta
    Quote Originally Posted by iEvo
    Agreed...the products Toyota has been putting out are, for the lack of better words, ugly. But they will still sell...people will still buy...regardless if they are bland and boring to drive, simply because it's a Toyota/Lexus.
    Newnan
    looks like a giant headache for future mechanics. wiring nightmare
    red@9 drtyhatch's Avatar
    That is about UGLY. Why can that not just make a vehicle with a normal body a hybrid?
    drtyhatch™
    Newnan
    because the tree huggers enjoy looking "special"
    Quote Originally Posted by greasemunkey
    LOL they look special alright!
    drtyhatch™
    The Slums of GA
    reminds me of the new camry
    Banned LS2ner's Avatar
    The Face
    wtf is that in the center console? looks like a mouse or something. that the shifter?? im confused.
    Everywhere
    Quote Originally Posted by Atlblkz06
    You didn't read the press release. For one it is 85% recyclable. It also has "green" plastics not available on other cars. The interior is all different.
    Hey it won't give enthusiasts a hard on but its a great addition to the Lexus lineup and will sell in droves.
    Don like 2 prof reed
    Apr 2004
    ATL and Baton Rouge
    Sorry i'll take a new Diesel from Germany.I've heard from people they are getting 48+ in the new TDI Jetta, 40 from a 335D, and even more so from others that are not available here yet (116d, A4 2.0D etc etc). Not to mention they make power and haul ass, damage the environment less to produce, are mod friendly, can get 6 speeds in just about all of them, and you don't have to deal with driving a hybrid.
    Islander
    Atlanta,GA USA
    Quote Originally Posted by LS2ner
    That's Lexus's version of the i-drive, which is found on the BMW's, though they claim it will be much, much more user friendly.
    it controls the Nav menu's, etc.
    Hell
    I was only talking about the drivetrain. The rest is all marketing BS. Metal in cars is nearly 100% recyclable IF you spend the time sorting it. So are most plastics, but that doesn't mean it actually gets recycled. About their "green" plastic - its probably weaker and cheaper lol.
    Plug-in hybrids are not that far away - I dont see why anyone would buy this.
    But in the end you're probably right - it'll sell in droves lol. sigh...
    Fresh meat
    South Carolina
    it looks like a camry w/ a new facelift. looks like a ford...uugghh.
