Results 1 to 14 of 14
Thread: B16 Shortblock
    D0 W3RK RedEj8's Avatar
    Macon
    Default B16 Shortblock
    Un-assembled. Out of a 99 civic SI. Was rebuilt .020 over. Was taken apart because it was thought the block had a problem but it ended up being the head. Motor only had about 2000 miles on it when It was disassembled. It is very clean. You only need new rings and bearings to put it back together. I guess a quick cylinder hone wouldn't hurt though.
    The crank, rod ends, mains and cylinders are covered in moly lube to prevent rust from forming while is was sitting. Rods and pistons are assembled.
    Includes Block, Crank, Rods, PR3 Pistons (.020 over), oil squirters, oil pump, rear seal housing, oil pan, oil pickup, windage tray and all the bolts for it.
    Price $150 obo
    Also have a set of B16 camshafts-$20
    And a set of 96 Civic coupe tail lights- $25
    Macon
    Bump..Make an offer I can't refuse..
    Special Rusbuilt's Avatar
    Knoxville, TN
    sent u a pm
    Macon
    Replied. Also cams and tail lights added.
    Macon
    B16 pending...
    Macon
    Bump!
    Macon
    Flaked.. Price drop to $150.. Add $10 and i'll meet you at Summit with it!
    sleeve me please?
    monroe
    is the block still for sale if so pm me!
    Macon
    turbos
    what bore are the pistons. and would you part them and ship them?
    pm me with details
    TOO BIG
    rolla rollin
    middle GA
    if i sell my ls block and head soon ill pick this up from you!!!!
    Columbus
    Good deal man. Bump
    Macon
    Pistons are .020 over. I'd rather not just part the pistons because I'd have to go get the pins pressed out of the rods.
    The pistons you see in the box are the stock bore pistons.
    Southside Ridin HATCH
    b16 oil pan?? for sale?
