Results 1 to 15 of 15
Thread: Anybody got a vag com I can borrow?
    Apr 2003
    Acworth/Kennsaw
    Default Anybody got a vag com I can borrow?
    My car is overheating and I need to see some readings on my sensors and module to see whats bad before replacing a bunch of parts. I have already eliminated parts that are not bad thermostat, water pump, fans, fan switch(just replaced it hoping that would be the problem.)
    If you can further help me figure this out with out a vag com, please do so. Thank you.
    This is whats going on, car is overheating at about 240-250 at idle. At highway speeds around 200-220. No DTC's or temp light flashing. No exact on temp but it has not gone pass the last notch/line before the red zone. Fans do not turn on when overheating. The fans do work when turning on the AC.
    Say Somethin'
    in that one girl...
    year make and model
    and wat engine, and how many miles
    weak civic
    Apr 2003
    Acworth/Kennsaw
    80k 03 1.8t forgot about that.
    Say Somethin'
    in that one girl...
    have u replaced your coolant temperature sensor to the green top?
    weak civic
    Apr 2003
    Acworth/Kennsaw
    I keep hearing the green top is causing alot of cars to overheat days after installing them. And no I have not.
    Say Somethin'
    in that one girl...
    the black top was the one that had over heating problems. they had a recall and replaced the black tops with the green tops
    weak civic
    Apr 2003
    Acworth/Kennsaw
    Yes I have read that for the 02 and later models. I was searching on vortex and a lot of people who replaced the black w/ the green still had issues. They switched back to the black and it fixed the problem.
    Say Somethin'
    in that one girl...
    hmmm idk
    i changed mine out a year ago and it works fine for me.
    and when u changed out the water pump, did u replace it with the metal impeller or the plastic one?
    weak civic
    Apr 2003
    Acworth/Kennsaw
    Metal Impeller.
    I just replaced the coolant temp sensor and still overheating. Fans are still not turning on.
    Do you know where all the fuses and relays are located? I know of the ones on top of the battery but are there anymore else where(has to be)?
    Say Somethin'
    in that one girl...
    this might help
    http://forums.vwvortex.com/zerothread?id=2810701
    and here is a pic of where the fuse box is inside the car
    weak civic
    Apr 2003
    Acworth/Kennsaw
    Oh ok thx. I forgot all about the fuse box behind the driver door.
    Apr 2003
    Acworth/Kennsaw
    Quote Originally Posted by turbo jetta
    this might help
    yea, them fuses be fine on my car. I have a feeling its my fan module.
    Say Somethin'
    in that one girl...
    i'll search around and see if i can find anything else
    weak civic
    bojangle JDMaccord's Avatar
    tap into the fan motor wires and check if it turns on?
    Looking for a professional photographer Gwinnett area but can meet just about anywhere!!!! Hit me up
    Apr 2003
    Acworth/Kennsaw
    Quote Originally Posted by JDMaccord
    Do what now? Do this to see if the fans work? The fans do turn on when I turn the ac on.
