Results 1 to 14 of 14
Thread: Help with idling problems.
    Norcross
    Default Help with idling problems.
    I got a b16 civic and i just cleaned out the intake manifold and cleaned the IACV and replaced the thermostat. Now my idle rises up to about 1.75k revs and falls back down to 1k and then rises back up. I did a lil research and supposedly i need to check my radiator hoses for air pockets or possibly clean my FITV. Anything else that it could be(other then those stated and other then vacuum leaks)?? reps for help
    Newnan
    idle air control valve..
    or a vacuum leak
    get a haynes manual.
    learn to english
    Norcross
    Quote Originally Posted by ChuckNorris
    or a vacuum leak
    i dont think u read my OP very well, but yea im aware of those, im just wondering if theres anything im overlooking before i work on it tommorow, thanks tho
    Southside Ridin HATCH
    just sounds like you should bleed the air pockets out and or its a vac leak..
    I know you said you are aware of those problems but thats probly the issue
    ATLANTA
    it sounds like a vac leak to me
    RX7
    JDM TYTE AnthonyF's Avatar
    possible vac leak. Did you remove the intake manifold?
    -Ant.
    The Carbon Fibered R6
    Norcross
    -Ant.
    thanks reps to all. yea i removed the intake manifold initially to clean it
    FITV
    xxxx mirz833's Avatar
    Duluth
    vacum leak
    or a vacuum leak
    i would have to agree check those
    Senior Member G.C's Avatar
    Forgot
    spray brake cleaner. if idle changes, thats where its leaking from
    :idb:
    ^^^ yea THROTTLE BODY CLEANER!!!! spray around mani and throttle body,if idle drops then thats the Leak
    Norcross
    forgot to update. but i found out my Throttle body was loose. Tightened it up and problem solved.
    J.R
    Down South
    ya same thing happen 2 me ex my throttle body gasket has not work properly(thanks autozone)
