Results 1 to 18 of 18
Thread: TOP 10 car mods of 2008
    1010011010 Atlblkz06's Avatar
    Hell
    Default TOP 10 car mods of 2008
    #10: Tampon Dispenser (For Automatic Vehicles)
    This is dedicated to the lady racer on the go! Featuring quick dispensing action, the Tampon Dispenser for Automatic Vehicles is the ideal match for any vehicle with an automatic transmission. The built in canister operates much like the clip of a gun, and has a capacity of 12. Extended clips may be purchased, depending on vehicle. Absolutely not for use with manual transmissions!
    Deep Discount for Hyundai Tiburon owners!
    #9: AWD Conversion Kit
    Been unsatisfied with the monster torque steer in your front wheel drive luxury car? Been annoyed by the rear end of your new high powered sports car sliding out in the rain and snow? Jealous of those folks with the big spoilers and pink performance parts? Let's face it: Only AWD cars have good handling. (Just ask anyone with an AWD performance vehicle.) To overcome the shortcomings of many otherwise nice vehicles, KaleCoAuto has developed this system! The lug-pulleys bolt directly to the wheel studs! If you can change a tire, you can install this kit. Please refrain from making left or right turns once this kit is installed. To enjoy the added handling benefits of AWD with this kit, is important that the steering wheel remains perfectly centered!
    #8: Adjustable powerband
    Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect solution! The power bands are made from titanium-injected rubber, with high grade 440 fasteners. Six links are included. One band is for horsepower, and the other for torque. You may use more than three links per side, but extreme caution should be taken!
    #7: A Round Tuit
    For the first time ever, KaleCoAuto is offering this exciting new accessory! The Round Tuit. We spent three years looking for this item, and finally have found it. This highly sought after item is a requirement to finish all those hard jobs that you keep putting off. Sold unpainted. We do anticipate offering them in different colors, if we ever get around to it...
    #6: Double O pipe Exhaust
    You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is dual input O-Pipe with standard finish.
    #5: Radiator Insulator
    The weakest part of your car is the likely the radiator. It is a simple matter of physics when we tell you this: Energy is lost through heat. Transmissions, as they lose more and more heat, begin to cause more loss of power. However, that's only a small part - The worst part is the radiator! All sorts of heat is lost through the radiator - in essence - losing the horsepower through heat! Not anymore!! KaleCoAuto brings you the Radiator Insulatior - Simply slip over your radiator and enjoy the power! KaleCoAuto radiator insulation is made from only the finest asbestos, and is guaranteed to trap 90% more heat!
    #4: High performance cross-drilled brake lines
    Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors.
    #3: Piston Return Springs
    KaleCoAuto has produced the highest quality piston return spring to date! High temperance chromed metal resists temperatures up to 300'f. KaleCoAuto piston return springs FORCE the pistons back into the motor, no longer relying on gravity! This effectively increases your revs, horsepower, and peak torque! You must buy one return spring per piston. Rotary engines require install of pistons for full compatibility. One per piston. Please specify if you are using a boxer motor!
    #2: Muffler Bearing
    Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right? That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCoAuto muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers. Also works well on heavy duty exhaust systems. One per muffler.
    #1: Engine Oil Bypass Kit
    Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!
    LOLOL good stuff
    Warner robins ,Ga
    lmfao
    xxxx mirz833's Avatar
    Duluth
    lol good shit
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Who knows?
    Daytona Beach
    5 litres of fun
    Hilton Head Island, SC
    lol very nice
    90 Mustang GT
    BBK/Fidanza/Centerforce/JET
    Norcross
    lmfao sweet mods
    Certified Gearhead atlxpat's Avatar
    atlanta
    i loled all over myself when i saw the cross drilled brake lines
    Rock the 40oz GTScoob's Avatar
    GA Tech
    lol, someone stole those from turninconcept.com's website. looks like they pulled them all down and replaced them with the UBER JDM Keyboard,
    http://www.turninconcepts.com/produc...roducts_id=471
    02 WRX Sport Wagon
    SwiperNoSwiping!!
    lirl..
    u remind me of a wigger !
    HAHAHA the brake lines was by far the funniest
    Da Nastyist Whipz Member #9
    macon
    ....engine oil bypass rules all...
    mr2 problem twincannon26's Avatar
    douglasville
    i lost it at the brake lines, but when i saw the muffler bearings i was in the floor. excellent parts.
    86 MR2 4age, 86 MR2 20V, 84 MR2 3lc RHD, 01 MR2 Spyder, 92 SE V6 5spd Camry.
    so maybe i have an mr2 problem.....
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    I actually used a "insulator" on my kart radiator
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Oct 2008
    Nice one. The AWD one was pretty funny.
    'Round These Parts
    Funny thing is that I've heard a guy use "muffler bearing" as a joke like 2 years ago... wtf?
    Leisa and S. 4 Life NM?
