Results 1 to 39 of 39
Thread: Homebrew'd wii, help please!
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    Default Homebrew'd wii, help please!
    I'd like to start this thread in hopes if getting an understanding on what needs to be done to make the copies/backups I have made from my wii games work on my wii. I have installed Homebrew and have burn the ISO game on my dvd-r but am not able to get it to work with the wii. If anyone knows ANYTHING ON THIS TOPIC THAT WOULD BE GREAT CUZ IM KINDA LOST.....
    Advan Kid
    what method I will look it up and try to help you
    Advan Kid
    Also Burn info would help.
    Program:
    Speed:
    DVD Name:
    ISO name:
    Raleigh, NC
    i really have no clue...
    I downloaded the game which was an .ISO and then burnt it using my "disk utility" on my mac . Now I'm trying to find a program that i can load through homebrew that will allow the Wii to read my burnt DVD. ohh and unknowingly i downloaded the newest wii upgrade. 4.3u I think
    Advan Kid
    The program you need to load to your homebrew is called Backup launcher 0.3 gamma(better than beta).
    Advan Kid
    Not all games will work, but as of now most do
    Raleigh, NC
    even with the fact that i have the newest software on the wii?....from nintendo...
    Raleigh, NC
    ohh and where do i need to put that file on my SD? thgere are so many folder on it now i have no clue where to put what!
    Thanks for all your help!!!
    Raleigh, NC
    i did all that and I got "DVD read err 324 no cISO" any ideas?
    Advan Kid
    sorry man I kind had to leave the house for a mintine.
    Check on it right now
    Advan Kid
    Are you sure it 4.3u not 3.4u
    Advan Kid
    Did you do this hack. This is the one for 3.4u. There is nothing on 4.3u.
    http://gbatemp.net/index.php?showtopic=118058
    Advan Kid
    1.Ensure your SD card is formatted as FAT. By default SD cards are formatted as FAT, so if you're not sure you can skip this step.
    2.(Optional) If you have an existing Zelda save that you want to backup, do so before proceeding:
    1.Put your SD card in your Wii and turn it on.
    2.Go into Wii Options --> Data Management --> Save Data --> Wii
    3.Find your Zelda save, click on it, click "Copy", and click Yes
    4.Put your SD card in your computer, and copy the "private" folder from the card to a safe place.
    3.Copy the "private" directory from the Twilight Hack download to the root of your SD card.
    4.Take your homebrew Wii executable (elf or dol file) and save it in the root directory of your SD card as "boot.elf" or "boot.dol" as appropriate.
    5.Put your SD card in your Wii and turn it on.
    6.Go into Wii Options --> Data Management --> Save Data --> Wii.
    7.Find your Zelda save, click on it, click "Erase", and click Yes.
    8.Open the SD card and select the "Twilight Hack" save that corresponds to your game region. Note: Some people are having problems with the Wii not "seeing" the save file on the SD card. If you are experiencing this, try setting the archive bit for the data.bin file - in Windows this can be either be done from the file's properties dialog (right click on it in Windows Explorer and check the box) or from the command line using "attrib +a <path to data.bin>". More info at #wiihelp on Efnet.
    9.Click copy and then yes. Now exit out of the menu.
    10.If you are using System Menu 3.4, you must immediately put the Twilight Hack to use. Turning off or running some other channel or game will have the System Menu delete the savegame again, and you'll have to start over.
    11.Insert The Legend of Zelda: Twilight Princess game disc and run the game.
    If you have the USA version of the game, load the "TwilightHack0" or "TwilightHack2" version of the game as appropriate (see above).
    Otherwise, load the only "Twilight Hack" save game.
    12.Once in the game, either walk backwards or talk to the man standing in front of you.
    13.Follow the instructions listed on the screen.
    14.Enjoy.
    Advan Kid
    After hunt all little more around
    This guy is on the same fw.
    the 324 error means you dont have cIOS installed man
    Install - IOS30-64-v1040.wad (Must be first) USA WII only
    Install - SystemMenu-v289.wad
    Install - IOS36-64-v1042.wad
    Advan Kid
    Raleigh, NC
    Thanks for all the links, now where can i get those files? I read the entire thread you linked me to but couldnt find were to get those three files.
    Raleigh, NC
    I have the IOS35-64-v1042.wad file but cant find the other two....
    Advan Kid
    Advan Kid
    Can't find other one seprate.
    But here is a file with most of them with out IOS30-64-v1040.wad.
    http://www.megaupload.com/?d=E5SXUNMT
    Raleigh, NC
    Thanks, my internet it down right now. When I can get back online I will give those a try!
    Advan Kid
    Yea mang just post up. I want to here the outcome.
    Raleigh, NC
    grr I have those files in my "wad" folder but i cant figure out what to do next, how to run them.
    Raleigh, NC
    DAMNIT!!! Well I got the Wii downgraded and went to put some software on my SD so I could play the DVD i have and while doing all this my gf wanted to play the wii fit. So i set it up for her and went to play it and the Wii told me that I nneded to update the system so i could play the game. HOW GAY!!! So now I'm on 3.3u and i dont know what I'm going to do. I also ran into a problem with my computer not wanting to read any of my SD cards.....joy...
    Raleigh, NC
    this is the link i used to install everything...
    http://thepiratebay.org/torrent/4614...___inAcrysis__
    Advan Kid
    I think 3.3u doesn't delete your homebrew so I think your safe.
    LOL
    Advan Kid
    Did you do the CIOS installer on your wii. Try that if you haven't
    Raleigh, NC
    i did do the installer, and was at the 3.2u at one point but still got the same # error
    Advan Kid
    Well you have to be connect to the internet. So The CIOS can install the a patched verison of the IOS.
    What game are you trying.
    Advan Kid
    Where are you at right now. What Firmware, Can you see the Wiibrew channel.
    Raleigh, NC
    I have the internet working on it, I'm back on 3.2u but cant play the wii fit game now...I'm trying to play the burnt copy of wii music. I finally got it to play but the screen it bigger then the tv and its in black&white
    Advan Kid
    well to play wii fit you got to install starfall and that will block the upadates. You need to force the setting to NSTC. Believe your Wii music is trying to run in PAL
    I have 4 up and working, 2 soft modded, 2 hard modded,
    I will sell you a 2gb sd card with eveything you need for $20, I will show you it works.
    Also if you're not using dvd-r minus, the games will not play right.
    Us2 imgburn on 2x for copying.
    Raleigh, NC
    Im using memorex DVD-R, I think i have everything needed to play the problem may be in burning it. I have a mac and am limited to using the Disk Utility, I burnt one disk on auto and it works however its B&W and is bigger then the tv (image is off screen) and the other one i burnt at 1x and it worked and now isnt...
    Raleigh, NC
    Its up and running!
    Advan Kid
    That good was it. Did you have to use force settings
    Raleigh, NC
    well i got another game to burn and that one is working. 2x burning is the best option rather the 1x and i'm working/waiting on more games...
    Raleigh, NC
    ok...now that I have traded my Wii to my sister im wanting to unmod the wii, anyone know how to do that? meaning I was to return the wii back to factory settings!
