Thread: HONDA/ACURA BUFFS LOOK HERE!!!!
    STILL HERE!! tron's Avatar
    loganville
    Default HONDA/ACURA BUFFS LOOK HERE!!!!
    OK
    car-93 acura legend coupe
    problem-the starter crapped out need to be replaced
    question-how in the hell do i go about doing it..
    plz help yes i have tried Google but i guess i suck at search engines
    and i could search for it on here but what are the odds there's a write up
    i have only been able to get a couple bolts out but im wondering if i have to remove something else to get it out cause right now it looks impossible
    -car and driver, 370z review
    disconnect battery
    remove cables from starter bracket
    disconnect the battery cable from the starter and stinger wire
    remove start bracket
    remove exhaust y pipe
    remove starter bolts
    rotate starter 180 degrees
    pull from between upper arm and axle
    on some model axle may have to be removed
    thats a short version of what shopkey says. ive never had to do it so i cant give u any pointers.
    loganville
    thanks man
    i'll tell you how it goes
    np
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    ^^^ do u work at honda dealership??
    NIKON Squad member 05
    Mah shit thread
    Where Am I
    disconnect battery
    WOW thats looks like a pain in the A$$ just to remove a starter...... Good luck man
    Quote Originally Posted by 404 THE DC4
    na just average every day mechanic.
    Quote Originally Posted by Turbodude06
    i did 1 on an isuzu the other day i had to remove the y pipe header cat motor mount and intake just to get it off. then after all that it had a fucking hole in the side of the block. right behind the stater.
