Thread: need help with my 93 civic
    Default need help with my 93 civic
    im haveing trouble wit getting it to idle and drive right the motors boggin real bad almost sounds like a subaru lol but i dont like it and ive changed out the throttle body and the map sensors i took fuel rail off and cleaned all injectors there spraying fine chane the distributor cap rotar button plugs wires i just cant seem to figure out wat it is its a d series motor 16 valve 5 speed if any one can help me please do u can call if u like my name is shane and u can reach me at 229 364 4913 thanks i would sure appreciate it
    North Augusta, SC
    What do you mean by it doesn't idle and drive right? Is it bogging down when you hit the throttle? Are you sure your timing isn't off any?
    Back to being stock and slow
    Default 93 civic
    yea i checked that someone told me it could be the cats clogged but ive tried everything that i can think of its fireing and getting fuel just boggs in low rpms and i can stomp it and when it hits id say 5000 rpms it opens up
    sounds like ur timing is off a tooth. If ur cat was clogged it wouldnt rev. mine clogged on my d15 and when i touched the gas it would feel like my car was having a seizure.
    What all is done to the car or is it stock?
    timing is off or you have a bad cylinder (subaru sound)
    Southside Ridin HATCH
    timing.. Or the subaru sound could be you have the wrong plug wires!!! that happend to my friend once... He was riding around for a week sounding like a STI!! LOL
    Sep 2008
    lithonia
    timing or crank sensor. i had a similar problem last week. it was my crank sensor.
    Slimm
    chill six7teen's Avatar
    Columbus
    are you sure your firing order is correct??
