Results 1 to 30 of 30
Thread: TRANNY FLUID QUESTION!
    Certified Gearhead jdmda9's Avatar
    Default TRANNY FLUID QUESTION!
    JUST ABOUT DONE WITH DOING MY SWAP ON MY TEG. ALREADY PUT OIL IN THE MOTOR AND NOW I HAVE TO DO THE TRANNY. HOWEVER IVE HEARD THAT PPL PUT MOTOR OIL INSIDE TRANNYZ AND RUN THEM ALL DAY. IDK ABOUT THIS ONE THOUGH CUZ I DONT WANNA PUT MOTOR OIL IN THERE AND END UP FU.CKING SOMETHING UP LATER ON! THERES TRANNY FLUID FOR A REASON RITE! SO WHAT TRANNY FLUID DO YOU GUYS RECOMMEND? ANYTHING GOOD AT AUTOZONE OR ADVANCED AUTO PARTZ? NAPA? OR SHOULD I GO TO HONDA? LMK PPL AND I REALLY APPRECIATE THE HELP!
    shhh...
    vtec game scArY. . !
    Southside
    You could go to Honda or could run Mobil 1 10w30
    like I stated, "You Could" lol
    DUH-KYOO-LUHHH
    just run redline 90w gear oil. only a complete fucking moron would run motor oil. wtf.
    1010011010 Atlblkz06's Avatar
    Hell
    Motor oil is a lubricant, Transmission fluid is hydraulic fluid.
    EDIT: Thought you were talking about ATF.
    DUH-KYOO-LUHHH
    well im guessing that its a manual tranny and "transmission fluid" = gear oil.
    IA Member blumagic04's Avatar
    somewhere
    Yeah tranny fluid is a hydaolic and a cleaner, you can clean parts with tranny fluid. You can't do that with oil. Dude don't fuck ya tranny up.......
    2004 SONIC BLUE GT MUSTANG
    Dropped
    .8000K HIDS.
    .FLOWMASTER EXHUAST.
    .K&N.
    WELL ITS A CABLE TRANNY AND YES IT IS MANUAL!
    shhh...
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Tranny fluid man
    Ohio asshole.
    I saw only one or two good responses.
    Just rean 80 or 90w gear oil. Of any brand. I for a while ran the cheapest gear oil I could find and had no problems.
    Now, having a good job, I run NOTHING but royal purple and lucas products.
    Switching mostly to Lucas now, however I got gains all across the board with Royal Purple.
    you CAN run motor oil in the trans, none of the 10w-30 crap. Just run SAE 30 or something to that effect no "number W" in it. Otherwise stick with gear oil.
    AWD
    gainesville
    X2 80W90 ANY BRAND
    Augusta, GA
    Quote Originally Posted by REDEVO777
    X2 80W90 ANY BRAND
    what an IDIOT!. dont put that junk in the transmission. Honda made MTF for a reason, USE IT!, it is about $4.xx a quart. Buy 3, use what you need and have leftovers.
    Honda/Acura uses Motor oil in there Gear boxes, if you use Gear oil it will eat the brass in the tranny, also if you use automatic fluid it will do the same!
    Either use
    1qt GM Syncro mesh with 1 qt 10w40 motor oil
    or use
    Honda fluid its 5 bucks quart
    I use the regular MOBILE 1 10W40 with no issues and I rebuild them and never a issue!
    NEVER USE
    Automatic fluid or Gear oil!!!!
    Takes 2 quarts!
    BABY EATER white93gs-r's Avatar
    Macon
    i personally run mobile 1 10w30, and i always have with no problem ever. but if you have to question, just get honda MTF. cheap and you know its gonna work.
    Southside
    all I can do is lol at this point
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    gm synchromesh.
    $25/quart.
    Quote Originally Posted by Homer Simpson
    gm synchromesh.
    $25/quart.
    Are you crazy its 6.99 @ autozone a Quart!
    SOUTHSIDE
    i've used 10w30 on every swap i've done no problems so far.........
    Wheres the money?
    McDonough
    i use 10w 30 and had no problems
    to many projects not enough money
    Senior Member G.C's Avatar
    Forgot
    same 10w 30 on last car didnt have problem.
    :idb:
    Either use
    or use
    NEVER USE
    u god dam right
    Wheres the money?
    McDonough
    Dont use gear oil in honda MT! Use 10w30 or syncromesh FM.
    Atl
    ok lets get this straight. dont use motor oil, atf, or whatever. Either use honda oem mtf fluid from the dealership. if u plan on high revvin all the time like we do, most def use gm synchrmesh!! its the best stuff out there for our application. here is the part number. 12345349. its like 12 bux a quart not 25. also the synchromesh at autozone is not the same. that stuff is brown lookin while the real gm stuff is burgandy. i rather pay the extra buxs to make sure it right.
    credibility and reputation
    SOUTHSIDE
    why would you high rev on oem fluids shouldn't you up grade fluids to performance stuff.....imoo
    Quote Originally Posted by HatchHero
    Quote Originally Posted by wrekonize
    u read it wrong.
    Atl
    u read it wrong.
    thank u. reps for u
    thank u. reps for u
    lol np. i read it the same way the first time around.
    ATLANTA
    run gear oil cuz tranny fluid is only good for a flush just us 90w oil
    RX7
    Low-n-Slow iEvo's Avatar
    Gnett
    yea motor oil in a trans is a no no. just get some gear oil. a manual trans isnt goin to be as picky as an auto
