Thread: teg tranny swap
    Gainesville
    Default teg tranny swap
    How much am I looking at swapping out an automatic tranny for manual in a "non gsr" teg ls/rs etc.
    R.I.P Val.
    K-Town (Kennesaw)
    yes please tell, because my friend would like to know too.
    VAL FOR PRESIDENT
    1979-2007
    Banned Jon00's Avatar
    Dec 2003
    Grayson, GA
    PM vteckid but im thinking around 600-800 with out parts
    $1500 parts and labor
    west of ATL
    i got most parts for this!
    "You can't spell CrAP without APC"
    4 sale:
    69 mercedeshttp://www.importatlanta.com/forums/...d.php?t=122901
    da ringmasta teggy 2nr's Avatar
    G county
    with the swap to a manual from a auto, would the quality be the same as if u had a stock manual? i mean will the gear-box feel, clutch, idle, etc... be the same as a true manual?
    if its done right it will feel exactly the same
    G county
    $1500 parts and labor? where at? do you know any reliable shops? thanks man
    Mainstream Peroformance
    that is for an LS or B16 tranny. that is NOT an ITR or GSR those add more money cause the trannys are more $$
    this includes
    Tranny, Clutch, Flywheel (STOCK)
    CM Cylinder
    Lines and hoses
    DOES NOT COME WITH ECU, you supply ECU
    G county
    i can just use an ecu pulled from a manual ls/rs/gs or does it have to be an ls ecu for ls tranny or rs ecu for rs tranny, etc...
    must be a 5 speed ECU. if its an LS/RS/GS they all use the same ecu to my knowledge. GSR is different
    G county
    thanks for the info
