Results 1 to 15 of 15
Thread: idle air control valve sensor
    Default idle air control valve sensor
    will any b series idle air control valve sensor work for a 95 GSR or does it have to by engine specific?
    must are interchangeable
    Default hey
    so any b series will work or no lol i need to know for sure
    Yes they will!
    just dont try a OBDO B series onto a OBDI or OBD II they are way differ!
    Matter fact you can use SOHC IACV on B series also!
    Yes they will!
    ok thank you very much!!!
    Welcome!
    Try and clean yours first!
    Take AIR and blow in the screen into the sensor and bolt it back down it might fix your problem!
    i didnt know you couldnt use OBD0 because i just transfered it from my other motor. but it is on an edelbrock intake manifold will that matter?
    Well the OBO B16 is way differ the bolt pattern is differ, but OBO ls will work!
    Quote Originally Posted by kpowerhatch
    No problem!
    im gettin a code 14 for some reason could it be the after market intake mani?i just replaced the iac and im still gettin the same code
    anyone know why its still throwin the code if i replaced the iacv
    Code be the harness is crossed up with another plug, or bad wiring, or ecu , make sure the Intake,Tb is clean too.
    Hwy 315
    try resetting your ecu...
    -jonathan
    [/URL]
    Jesus Christ is my Savior
