Thread: code p0170 wtf is this!?
    LAWRENCEVILLE
    Default code p0170 wtf is this!?
    1999 honda civic it does not have a check engine light on but i was checking readyness with my scaner an saw i have a code po170 pending. what is this for?
    Hella stock member!
    fuel trim, could be many things,
    Bad O2 sensor,
    vac leak,
    weak fuel pump,
    ECU,
    injector,
    timing ,
    etc
    LAWRENCEVILLE
    fuck where to start!
    Hella stock member!
    Quote Originally Posted by silversol
    o2 timing and vac but thats just me. all easy scan tool will tell u about the o2. timing easy to check no need to explain. as for vac leaks some brake parts cleaner.
    Love a good V8 Swap fly-n-low's Avatar
    AL
    My CEL was on when mine popped up. I replaced my secondary O2 sensor and that fixed the problem. A week later the code popped up for my Primary O2 sensor and replaced that one as well.
    FS/FT 2000 Integra GSR. 119,xxx All Original.
    PM me if interested!
    \m/>_<\m/ dorin48's Avatar
    Canton
    p0170 is a lean condition on bank 1. You only have one bank of cylinders so thats easy. Most common problem that throws this code is a clogged/old fuel filter.
    AL
    I also forgot to mentio that at the same time I replaced my O2 sensor I also adjusted my valves. Check your compression/Leak down levels to see if one of them is out of specs. Could be a valve is too tight/loose. Tech book recommends this before other troubleshooting.
    4cyl Hemi Turbd4DE's Avatar
    K Town/Barrett Pkwy
    ASAP NorthWest Ga Chapter VP
    www.ASAPCarClub.com
    Kennesaw MEET Check it out>>>>> http://www.importatlanta.com/forums/...d.php?t=250694
