Thread: 95 ford taurus transmission
    step sticky stephen's Avatar
    Default 95 ford taurus transmission
    alright, so i have a little issue. i just replaced the tranny in a 95 ford taurus (axode tranny) and the pan keeps leaking. initially, the pan was pouring out fluid (i poured 2gal on the ground). i removed the pan, went ahead and replaced the filter and gasket...put it back together...and it stopped pouring, but now constantly drips. it's dripping between the pan/gasket/tranny. there's no hole or anything, it's just dripping. i checked all of the bolts, they're all tight. hopefully someone on here has ran into an issue like this.
    LAWRENCEVILLE
    bent pan?
    Hella stock member!
    Cork gasket is your problem , or bent pan, or its coming from the rear main seal!
    also I seen if they dont get clean perfect before installing new gasket it can cause it to leak
    yup
    appeciate the tips. I think someone over tightened the pan & caused the edge to bend. it has a rubber gasket...not cork so i'm sure that's not the issue. i'm going to pull the pan from the old tranny & put it on the new(er) one & see if that helps.
    I was hoping any of those weren't the problem. that pan is a pain in the ass to remove...no drain plug FTL! well...we'll see what happens tomorrow!
    Cork gaskets don't leak when installed properly. I'll use 10 corks before I use 1 rubber.
    Quote Originally Posted by stephen
    Throw the rubber gasket away. They will never seal. Get a duraprene pan gasket and don't over tighten it.
