Thread: Idle and squeal
    One Curve At A Time
    Default Idle and squeal
    Ok, There is a squeak in my 1995 Mazda Miata that happens when in reverse, or slowing down when in gear. The sound goes away when the clutch is engaged or the car is out of gear. The sound slows down with the RPMs. So far my guesses are a transmission mount or a loose pulley. All of my belts look good.
    The car also bumps when the car is at idle like at a red light. Just a slight bump felt in the car with barely any change in RPMs. It happens every 30 secs or so, or sometimes every couple minutes. All my hoses look good, so I don’t think it is a vacuum though I could be wrong. Ideas or guesses?
    97 DX Civic w/ H22 FS
    Dec 2008
    either, belt is to loose or to tight...spray tire shine on it.
    secondly...sounds like a spark problem.
    One Curve At A Time
    Ight, me and a friend gonna trouble shoot it today. thanks for the suggestions
    One Curve At A Time
    After a friend listened to it, the squeal location is the rear half of the car
    I had a squeal in the rear of my car a while back, only in reverse, it went away though and never came back lol.
    North Augusta, SC
    That means whatever was making the squeal ended up falling off. lol
    Back to being stock and slow
    all is lost...
    Williamson
    Could be as simple as the brakes in the rear are in need of replacement. Motivations used to squeak/squeal in reverse when his dsm ran If you brakes are semi mettalic sometimes the metal pieces can hang out and scrape the rotor/drum...
    North Augusta, SC
    Quote Originally Posted by Five0z28
    The dsm still runs fool... It just won't go into gear.
