Results 1 to 40 of 50
Thread: ls motor =)
    myspace.com/zeebzob Ferio4ya's Avatar
    Columbus
    Default ls motor =)
    so i'm swapping my old b7 out of my eg Ferio, and dropping a b18a1 in. i got all the harnesses, motor mounts, tranny dizzy ecu axles and all that other good stuff for the obd1 conversion. after the motor is dropped in though, i was wondering how to build this motor to reach around 230 crank hp competely N/A. cheapest and most effective ways possible. recommended brands, bad brands, what is safe and not safe etc. thanks guys! OH and i'm not really willing to sacrafice torque haha
    Versus
    Hwy 315
    you'll find it hard to squeeze 230NAwhp out of of a b18b building this engine yourself (unless you're a highly skilled machinist with all the proper equipment just chillin at your place )
    Stick with name brand bolt on stuff, typically the more expensive, the better. As far as machine work goes, which will be vital to your engines' success, check the sticky in this forum the Vteckidd made. That's a good guide to have money well spent.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    140 on one wheel
    columbus, ga
    why would you need to do a obd1 conversion on a obd1 car Youd be better of boosting it. You could make that power level very easily and very safely on around 6-7lbs. And it would last for years.
    Unknown
    Dec 2008
    southside
    Quote Originally Posted by se7en
    -jonathan
    he said crank hp not wheel. which should be about 200whp
    griffin ga
    stroke it long an hard with eagle rods be good start at least
    Hwy 315
    Quote Originally Posted by juicestang
    which is why I specified "whp" - even then, it'd be hard to put that kind of power down (non-vtec) without extensive machine work being performed, regardless of bolt on mods.
    He's going to have to bore it out to 84.5mm, use cams with ridiculous duration and lift (not very daily driveable), at least 12:1 compression (probably higher), 1mm oversize his valves, port match everything, and be very picky about which header and intake manifold he goes with. Not to mention the infamous dyno tuning. It's possible, but not for those with small checkbooks and only one mode of transportation.
    -jonathan
    [/URL]
    Oct 2008
    south side...clay-co
    Quote Originally Posted by -S Double C-
    the car is obd1 but he said the motor is a b18a which only comes in obd0 therefore he would have to convert the motor to obd1 hope that answers your question
    Out in the Boonies
    get a vtec head.
    Warner robins ,Ga
    just get some 405 cams, do crazy headwork, 12:1 or higher pistons, and alot of tuning.
    Warner robins ,Ga
    Quote Originally Posted by DC2NR
    get a vtec head.
    Middle, Ga
    Quote Originally Posted by xdavidscenex
    LOL, so when are you going to throw a Vtec head on your Integra?
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Warner robins ,Ga
    i have an AP1 now.
    Ferio4ya if you need some BC0022 cams, golden eagle cam gears, gsr oil pump or etc...lmk i might sell my stuff. i have a friend thats selling a set of OEM CTR pistons with rings, but im not recommened them on any all motor ls...
    LS Resurrection
    Fulton County, Union City
    gsr tranny
    building an all motor ls is a waste of money.
    Southside of The Jungle
    Quote Originally Posted by yunglaosta
    gsr tranny
    b16 FTW!
    LS Resurrection
    b16 FTW!
    lol either way it goes its good. i say gsr because its gears arent as short as a b16
    turbos
    yea a b16 trans means you run out of gear at 120mph. but a gsr trans will get you up to about 135mph.
    either introduce a little "juice" or boost it.
    TOO BIG
    Quote Originally Posted by seanrg1116
    GTFO b16 tranny goes to about 150mph at like 7600.Which is well over 120mph and gsr has to do over 135 if b16 can do 145-150mph
    Hwy 315
    you're correct - IF you're looking for pure HP numbers... some would also say it's a waste of time to build any type Honda engine at all... why modify a car period? But those people have their own opinions. It's all preference... i prefer to NOT have vtec and enjoy every minute of it.
    -jonathan
    [/URL]
    Duluth, GA
    wtf?
    my b16 eg gave out at 110 at 8000
    and so does decepticon's b20 eg on a b16 tranny
    it does...but not much... I've had this too
    Columbus
    so boosting the ls on 5 to 6 pounds would be ok with stock internals daily driven? or should i get eagle rods and after market pistons?
    ALSO, if you guys know anyone selling a VTEC head for a b-series let lmk!
    btw, i have a gsr tranny already bolted in =)
    Versus
    140 on one wheel
    columbus, ga
    Quote Originally Posted by Ferio4ya
    the guy i got my car from was boosting 8lbs on a tiny t3 turbo for 3 1/2 years before i got it and making 228whp then i got it and upgraded to a 57 trim and turned the boost up to 11lbs and have been making 273whp for around 7 months now. And ive put 30k on my car since ive had it. Compression is still 180 all across the board and doesnt burn oil or smoke one bit.
    LS Resurrection
    ahhh gsr tranny helps alot lol. well if u boost i think 7 psi would be da limit on stock internals.
    140 on one wheel
    columbus, ga
    im still running the ls tranny on mine i dont think the gsr would improve any.
    LS Resurrection
    my cousin has a 4 door gsr and put a ls motor in it (idk why lol) and with the gsr tranny made it run a helluva lot better
    140 on one wheel
    columbus, ga
    for all motor purposes yeah your right but ive ran just as good times at the track as others around the same power level as me but i had a heavier car. Plus i like highway runs, anything below 50mph i spin so i dont need the faster acceleration anyways.
    Quote Originally Posted by CoOkIe-MoNsTeR
    wtf?
    What kind of tranny do yall have are you sure you dont still have a govenor enabled.
    you have a ls and anything under 50mph you spin We are talking about all motor right?
    140 on one wheel
    columbus, ga
    no im boosted,read the sig lol! I gave up on the all motor theme after i was the first in GA to do the H2B swap. Turbo's top ends are sick and you can acheive the same or more whp with far less money!
    -jonathan
    Liar.............
    NOOB
    Alabama
    Supercharge it!!
    Cheap way to DIY and then u would just need a tune for more. I had 91 civic with b18a1 and couple people told me how they got 217 and 228 whp and i believe that was without a tune.
    But to go cheap get JRSC specifically for LS non vtec, use the 7 pound pulley, get injectors one or 2 steps over stock, header, freeflow exhaust. that is for stock setup without having to break your wallet as much as turbo. Key to it would be to be 2 get good deal on the jrsc first then all else will be good to go. This should get u 210 at the crank.
    If u want to get the 217 and 228 whp u need the 9 pound pulley and have to have the water mist spray to keep it cool, definitely go 2 steps up on the fuel injectors, cold air intake, need chipped ecu and tune it. With good tune u may squeeze more.
    Good luck.
    85 Ae86 hatch 3tc .040 over
    2005 REPSOL 1000 RR Fs/ft
    81 Starlet built 3tc N/A
    Gts/sr5 parts for sale
    Quote Originally Posted by RollaAce
    Supercharge it!!
    Good luck.
    For the price of a JRSC which I believe is like 2500$ you can build a all motor setup(LS/VTEC) for that price and will run the same times at the track.As a boost application with around the same amount of cash spent,just all depends on what you want to do myself I like all motor better than boost.
    NOOB
    Alabama
    U can get used ones for around $1000, that's what i would've done.
    Columbus
    thanks for the advice guys! =)
    Versus
    NOOB
    Alabama
    the advantage of the supercharger is u would have all the power available through the whole powerband. Also raises the rpm limit by about 1000rpm. It'll keep more power at redline with less dropoff as opposed to stock engine. Power at redline would still be 160+ whp not bad for a lil civic.
    Columbus
    i agree man. PLUS i hear people boostin all damn day. but rarely do i hear about supercharging. maybe i'll give that a try instead. doing research now.
    Versus
    Columbus
    nah, not supercharging it. lol, i believe i've been convinced to boost. 5 or 6 lbs, stock internals, later down the road i'll get vitara pistons, eagle rods and up the boost. depending though will need a good tune. BUT WAIT. would a VTEC head help any with a boosted motor or would that end up being a waste of money???
    ALSO, why would you put take out the gsr motor and drop an ls motor instead??
    Versus
    Hwy 315
    Quote Originally Posted by kkiepvvessau
    Liar.............
    do i even know you? vtec -
    1) yes, of course Vtec would help with a boosted engine - a turbo multiplies HP exponentially.
    2) you would take out a GSR engine to drop in an LS if you wanted slightly more torque (stock -vs- stock)... again it comes down to preference.
    -jonathan
    [/URL]
    turbos
    vitaras are for the d-series
    keep researching kid
    TOO BIG
    athens
    ..no..theres an obd0 and an obd1 b18a..
    Quote Originally Posted by jrhatcheh2
