Thread: misfire
    Sep 2008
    lithonia
    Default misfire
    aight. my wires are correct but still gotta misfire. what are some other possible problems? im guessing either the distributor is bad or the timing is off by a tooth. any extra knowledge is greatly appreciated.
    Slimm
    turbos
    what year?
    friend of mine has an 96 civic ex and he was throughing missfire codes until we changed the Headgasket.
    I would start by changing the plugs first
    TOO BIG
    plugs, wires, dizzy, burnt valve, headgasket
    southside ATL
    start by small stuff. spark plug, spark plug wires. distributer cap.
    Sep 2008
    lithonia
    98 civic. gotta d15b in it. i have heard people talk about the d15b not having the 2 vtec solenoids on it. mine has 2. i dont know if that makes a difference, but i thought id throw that in there. did plugs, wires, cap, and rotor button. havent swapped the distributor yet. i pray its not the head gasket.
    Slimm
    turbos
    two v-tec solinoid means you are very slow (well slower than ur average slow honda)
    v-tec-E FTL
    HG on that car can be done in a few hour with a little patience.
    U need to do a leak down test
    TOO BIG
    Sep 2008
    lithonia
    slower than a b series, maybe, but other d-series (depending on mods), not necesarily. the 3 stage vtec is just as strong, if not stronger, than any other d-seriees vtec engine. the zc may give the d15b some comp, but it will be very close.
    Slimm
    Love a good V8 Swap fly-n-low's Avatar
    AL
    My GSR had a misfire code right after I purchased it. I ran a compression test and that cylinder was low. I had a valve that was very tight, so tight that I couldnt even get the smallest feeler gauge in there. Once I put it in spec, the compression test went up to specs as well and I cleared the code. Hasnt happened since.
    FS/FT 2000 Integra GSR. 119,xxx All Original.
    PM me if interested!
    DUH-KYOO-LUHHH
    a friends d16 non vtec did the same thing, he had to replace the whole distributor. then he sold it and 3 days later BOOM. haha
    Ohio asshole.
    If you have two Vtec solenoids your ARE going to be WAY slower. Unless your pushin about 30 psi.
    Friend of mine just got rid of his CX with Vtec-E. It was the most gutless car I've ever driven. I have a D15b In my g/f's car to replace the Z6 that broke a rod. I've got the Z6 head on it, and it runs VERY well.
    Check your timing. That was a problem we just had with a DA. If you've changed everything else you said you changed, that would be, aside from a leak down, one of the easiest things you could to do try and remedy it.
    Sep 2008
    lithonia
    havent dont the leak down yet. i gotta friend checking out the timing as we speak.
    Slimm
    Sep 2008
    lithonia
    D15Z8
    VTEC-E
    Found in:
    1997-2000 Honda Civic LS (European Market)
    Displacement : 1,493 cc (91.1 cu in)
    Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
    Compression : 9.6:1
    Power : 84 kW (114 hp) @ 6500 rpm
    Torque : 134 Nm (95 lb·ft) @ 4500 rpm
    Head Code : P2J
    ECU Code : P2P
    VTEC Switchover : 2500 rpm
    Valvetrain : SOHC VTEC-E (4 valves per cylinder)
    Fuel Control : OBD2 MPFI
    [edit] D15B
    VTEC
    Found in:
    1991-1999 Honda Civic VTi EG4 (Japanese Market)
    1992-1998 Honda CRX VXi EG1 (Japanese Market)
    Rod Length : 137 mm
    Compression : 9.6:1
    Power : 128.22 hp (130 ps) @ 6800 rpm & 101.9 ft·lbs (14.1kg/m) @ 5200 rpm
    Redline : 7200 rpm
    Fuel Cut : 7411 rpm
    Head Code : P08
    Fuel Control : OBD-1 MPFI
    [edit] D15B (D15Z7) (with 3 stage VTEC)
    3-stage VTEC
    Found in:
    1996-1999 Honda Civic VTi EK3 and Ferio Vi
    Rod Length : 137 mm
    Compression : 9.6:1
    Power : 128 hp (130 ps) @ 7000 rpm & 102 lb·ft (14.2kg/m) @ 5300 rpm
    Fuel Control : OBD-2 MPFI
    Slimm
