Results 1 to 3 of 3
Thread: FS: D SERIES PARTS CHEAP
    Default FS: D SERIES PARTS CHEAP
    i have a hydro 5 speed transmission that came off my running single cam d15b7 but i blew the motor. i have already taken out the motor and have all parts in my garage. i also have most of the parts off the engine im parting out, like: DISTRIBUTOR, CLUTCH(OEM around 600 miles), HEADERS(stock), o2 SENSOR, FLYWHEEL, HEAD (NON-VTEC MOTOR), AXLES, ECU, STARTER, INTAKE MANIFOLD,GSR THROTTLE BODY, SHIFT LINKAGE, SHORT SHIFTER, FUEL INJECTORS. and anything else you might need of the motor
    D15B Transmission - 100
    OEM D-Series Clutch w Flywheel - 50
    OBD 1 D-Series Dizzy - 75
    D-Series Stock Exhaust Mani w/O2 Sensor - 20
    GSR Throttle Body - 50
    P06 ECU - 40
    Complete gOOd head bad block d15b7 - 40
    Call Luis at 404-558-6234
    Attached Thumbnails Attached Thumbnails -1141f013c3k53m63ld8cm9307632d2d321078-jpg   -1231g31473n73k03l38cm01d68de037201ffa-jpg
    building the new ef revized_DX's Avatar
    northeast ga
    trades for the clutch?
