Results 1 to 3 of 3
Thread: Westin Billet Grille Insert, Horizontal Style, for Ford F-150 and F-250LD
    Banned BOBA-GA-NUSH's Avatar
    METRO AREA
    Thumbs up Westin Billet Grille Insert, Horizontal Style, for Ford F-150 and F-250LD
    Horizontal Billet Grille by Westin
    I have a few things that dont need, Insert is new in box, & still wraped in plastic.
    $75 o.b.o also accepting trades
    34-0220 Horizontal Billet Grille
    1999, 2000, 2001, 2002, 2003, 2004 Ford F-150 and F-250LD Heritage Edition grille insert, logo covered
    Add the ultimate in style to your vehicle with a Horizontal Billet Grille by Westin. These grilles are custom fit to your specific vehicle using the most modern computer aided design techniques. They are then cut from aircraft quality 6061-T6 solid stock aluminum using the latest in CNC machining techniques. Each grille is hand TIG welded ensuring the cleanest welds possible with aerospace quality tolerances. The Horizontal Billet Grille is then polished to provide a perfect bright chrome match finish. All of the Westin Billet Grilles are tested to assure durable construction and long lasting finish. Because they are designed for your specific year, make and model, you can be sure of a perfect fit, and the included hardware helps to provide a simple installation over your existing factory grille. All this means that you get the sturdiest and best looking Horizontal Billet Grille on the road and the easiest installation possible.
    • Custom designed to fit your vehicle perfectly
    • Constructed from aircraft grade 6061-T6 solid stock aluminum
    • TIG welded for highest quality finish and strength
    • Polished to a bright chrome match finish
    • Tested for finish and longevity
    • Bolts over existing OEM grille, no cutting required
    • Easy installation with the included hardware takes less than 30 minutes
    • 3 year warranty
    pm me for any questions thanks
    Attached Thumbnails Attached Thumbnails -002small-jpg   -001small-jpg
    METRO AREA
    Talking
    LOWBALLERS WELCOME
    MAKE ME AN OFFER
    METRO AREA
    TTT
    O.B.O
