Thread: ITR transmission
    southside ATL
    Default ITR transmission
    k i got a itr transmission and it grinds in third gear.. alot of people told me about the GM syncromesh and thats what im planning on getting.. but someone told me i have to mix it with something else? and how many quarts will i need?
    also it is kind of hard for me to get in first gear now and im thinkin its the short shifter. personally i dont like the short shifter and i wanna change it back to normal.. wat all would i need?
    3 quarts, i never heard about mixing it
    Duluth, GA
    buy any b series shifter and change that bish...it's easy as pie
    southside ATL
    Quote Originally Posted by Benefit
    yea me neither. its 20 a quart so 60 bucks shiit.
    southside ATL
    Quote Originally Posted by Captain-Obvious
    i can use the same bolt thats on it right now?
    its actually 2.4 QTs, you can find GM Synchro mesh for much cheaper than $20 a quart. Its usually $8-11 online.
    make sure you buy the LSD Friction Modifier to go with it.
    If its a SLIGHT Grind, it will be better, but if its grinding it means there is damage, and eventually you will have to fix the synchro.
    southside ATL
    Quote Originally Posted by Vteckidd
    is that wat the guy was talkin about mixing it?
    yes prob
    southside ATL
    k thnx all. ima get that done this weekend.
