Results 1 to 40 of 48
Thread: since when is nitrous considered N/A?
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    Default since when is nitrous considered N/A?
    i'm not going to name names, but i've noticed a person or two claiming their ***** to just be n/a at right about 3** whp.... i always thought a nitroused car was no longer considered N/A. am i just retarded?
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    you're retarded, but if you're spraying that is a form of forced induction
    2006 Evo IX - Bolt ons
    Fool Got A s2000 S II K's Avatar
    12.2 @ 115mph
    RESIZE PIC PLEASE
    ive never considered nitrous a form of FI. FI is when you raise the intake to pressures above atmosphere, something nitrous doesnt do.
    2.3 Evo 8
    Guest
    My evo is stock. My hood latch is broketed too. <<< Boris voice
    Lil' ol SmackedInATL's Avatar
    Maybe not FI by those standards, but it is definitely a power adder and NOT N/A!!
    FUK IT! bowdown201's Avatar
    Next Door
    lol whys it so important anyways
    Quote Originally Posted by SmackedInATL
    no its a power adder but the motor is still n/a not fi
    all your really doing is adding more oxygen to create a bigger boom.
    In the land of the slow cars
    I hate to ask, but how is forcing something that helps a motor combust down into your intake manifold considered N/A. You are Inducing something by force (Not Oxygen) into the motor...
    MAY CAUSE CANCER Psycho's Avatar
    Standing Right Behind You
    If an N/A engine has nitrous, it's still an N/A engine. It just means you're running a combustion additive. It's exactly like redrum said, nitrous doesn't raise the intake pressure. It just raises the oxygen content of the gas in the cylinders.
    Damn it, you posted before I could finish writing mine.
    2.3 Evo 8
    Guest
    Who cares!
    Quote Originally Posted by stillaneon
    Redrum has already explained why. By your logic, why would an engine with fuel injectors still be considered N/A?
    Aspirated would inply air.
    I guess I always thought fuel injectors forced fuel into the firing chamber, not the intake manifold.
    My bad
    Newburg, MD
    ...depends on ... if you are grudge racing or..... if you are telling the truth
    RIP Kaleb Mashburn
    Unknown
    Dec 2008
    nitrous almost doubles the cylinder pressure...so its def forcing something.
    what do you consider guys running turbo and nitrous?
    Stockbridge foo
    LOL
    Quote Originally Posted by AlliRae
    Jason..
    Bingo
    So according to these standards I could have a 650whp N/A GTO... Hmmmm...
    Nitrous is a power adder. It does not make the car FI.
    Val for president!
    Facebook.com/TracyATL
    everywhere & nowhere
    1st you have to break down the term N/A.
    By adding nitrous, does your engine continue to aspirate naturally?
    And when it breaks --- will broke ass GM pull it into the service bay?
    Nitrous does not force air, it is a cooling component. It also adds more air because nitrous splits into oxygen and nitrogen. The additional oxegyn makes it to where you can add more fuel.
    Val for president!
    Newburg, MD
    Quote Originally Posted by collins
    .... better would be to say you have a (insert gtos stock hp here) stock gto
    heheh
    RIP Kaleb Mashburn
    Cooling is a by-product of spraying. Not by design - just an added benefit. But is it REALLY --- hmmm. Ever seen increased oil temps and EGTs on a dyno during a nitrous pull?
    (playing devils advocate to get everyones head in the game)
    Either way, it does not "force air" which, by definition, makes a car FORCE inducted. Like I said, in addition to cooling (bi product of the following) it also adds more oxygen to the mix for combustion purposes , which means you can add more fuel.
    But I hear ya
    Val for president!
    2.3 Evo 8
    Guest
    Quote Originally Posted by TIGERJC
    Nitrous is FI? Take notes! You're getting SCHOOLED by Tracy!!!
    http://en.wikipedia.org/wiki/Forced_induction
    Forced induction can be used to improve the power, efficiency, emissions, or combinations of same, without much extra weight and minimal modifications to the engine architecture. The two most common forms of forced induction are turbochargers and superchargers, which both compress the air entering the cylinders, but use different methods to obtain the requisite power. Functionally, they are much the same. Since only so much power can be had from a given amount of gasoline, the more gasoline can be burned in the cylinder, the more power can be produced. However, simply adding more gas beyond the optimal air/fuel ratio (commonly called "running rich") does nothing for power. An engine can only take in so much when breathing air at atmospheric pressures, since the capacity and number of cylinders is non-variable. Hence, the only way to get more air into the cylinder, and therefore produce more power, is to increase the pressure at the intake.
    All we've considered up to now is increased power, so how does forced induction improve emissions or efficiency? One of the primary concerns in internal combustion emissions is a factor called the NOx fraction, or the amount of nitrogen/oxygen compounds the engine produces. High combustion temperatures lead to a lower NOx fraction, and since gasses heat when compressed, the more gas is compressed in a given volume, the hotter it will get, and the lower the NOx fraction will be. Since forced induction increases the amount of gas being compressed, it increases the heat generated when compression occurs. Since colder air is denser, it is most desirable, from a power standpoint, to have cold air coming in, but better from an emissions standpoint if the air is hot. In a perfect world, incoming air would be frigid, and the compression would be high enough to dramatically and rapidly increase cylinder temperatures, reducing emissions significantly.
    Two of the commonly used forced induction technologies are turbochargers and superchargers. They differ primarily in the power source for the compressor. There is a difference between forced induction and power adders. A power adder is anything that improves an engine's power output, which does not necessarily mean increasing charge density. Oxidizing technologies such as nitrous oxide injection systems provide improved power, but are not a form of forced induction.
    Reps to Tracy!
    Quote Originally Posted by 2.3 Evo 8
    Reps to Tracy!
    AWWWW shit! I learnt something in all my years in this game. I guess I can thank all the haters for making me stay up on my game. I never wanted to be just a stupid girl who sits behind the desk, so I sought out information just so I could school our customers.
    Val for president!
    2.3 Evo 8
    Guest
    Forced induction is "compressed air", nitrous is only compressed in the bottle, not compressed during the "spraying process".
    2.3 Evo 8
    Guest
    You must spread some Reputation around before giving it to Tracy again.
    Sorry sweetie, no soup for joo!
    I knew that - that's why I put "playing devils advocate" in my post.
    Pumpkin, You dun know shit. Quit trying to steal my thunder. IAM THE WINNAR! :P
    Val for president!
    2.3 Evo 8
    Guest
    For the record, I was not suggesting that nitrous is a means of FORCED induction, for the main reason that it isn't compresing air into the combustion chambers. It being a power adder, however, brought up the question of is that engine still considered to be naturally aspirated?
    Quote Originally Posted by Tracy
    LMAO @ "pumpkin" !! You STILL remem that? LMAO!! That's a classic inside joke from what - 2004? 2005? LOL.
    Quote Originally Posted by the bullitt
    Mega-charged:boobies:
    2.3 Evo 8
    Guest
    Yes, it's still N/A. it's just not "stock".
    1HOTA4 T.S.'s Avatar
    Jan 2003
    Rockin' Buford
    sweet collins slap a 250 SHOT on that bitch and its still considered n/a and you could pull the Thacker and just claim its stock too! i got a 2 stage 75 shot in my garage you can borrow
    Daytona Beach
    Never.
    Anyone that says otherwise hasn't a clue.
    2.3 Evo 8
    Guest
    Thacker only said his cars were "stock" to piss everybody off, and it worked. It always got under peoples skin when he would say it.
