Results 1 to 4 of 4
Thread: Current Set-up/ a few questions
    F.T.W.K.T.A.
    Dalton
    Default Current Set-up/ a few questions
    my current build/set-up consists of;
    Head:
    P08 D15b vtec head PnP'd by turbo dynamic
    3 angle valve job (valves and head)
    New OE valve seals
    OE valves
    Skunk2 Valves spring and retainers
    Skunk2 Camshaft
    Skunk2 Adjustable Cam Gear
    Ported and Port matched d15b intake manifold
    Block:
    SOHC ZC block with a KMS block gaurd
    Arp head studs
    Cometic headgasket
    Vitara Pistons
    Tuner toy rods with ARP2000 rod bolts
    ACL Race Bearings (main, rods, thrust washers)
    4.5lb lightened Fidanza Flywheel
    Clutchmaster Stage 3 clutch
    Turbo:
    Pipping; 2in on the hot side of the IC and 2.5in on the cold side
    Massive FMIC 32x16x2.5
    450cc injectors
    Old nopi BIg tube tubular Manifold
    HKS style Wastegate
    IHI warner ishi Turbo i think its a .48/.52 but im not sure
    Greddy type RS BOV
    Im not sure if im forgetting anything.
    What i was wanting to know is how much boost can i push i shooting for 15-20lbs or whatever will get me close to 300whp. does anyone know what to expect out of a d-series on 15lbs.
    94 civic Dx 4dr - N/A Ls/Vtec
    94 Del Sol Si - Project O'SH is GO!!!
    91 Accord Lx - Totaled
    North Augusta, SC
    I personally wouldn't have went with a really light flywheel on a boosted application... Lose to much RPM between shift. But anyways, sounds like a good set up... I am guessing around high 200's on 15 lbs of boost on current setup...
    Back to being stock and slow
    AKA THE BROWN MAN
    Kennesaw, Georgia, United States
    looks to be nice build specs i think w/ a real good tune mid 200 g/l with it keep us posted on this wanna see vids and pics
    F.T.W.K.T.A.
    Dalton
    250+ SOUNDS PRETTY GOOD!
