Results 1 to 17 of 17
Thread: NEED HELP PLZ!!!
    southside ATL
    Default NEED HELP PLZ!!!
    ok so long story short the bolts broke in half in the LCA that attaches the spindle. and also the one in the strut.
    since the bolts are stuck in there because they broke, i cant take it out.
    the shocks and the bolt holes are not aligned so i was wondering witch bolt do i remove to make them align?
    heres some pics for better explanation..
    ^thats the two bolts that broke in half..
    which bolt do i remove to make them aligned?
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Take a bar and jump push it down to align them
    LS Resurrection
    Fulton County, Union City
    Quote Originally Posted by STRteg
    pry bar and a big ass hammer will do da job
    southside ATL
    yea. i keep trying to jump on the spindle and its too stiff to move down to the right alignment. wat can i do!
    Oct 2008
    Quote Originally Posted by j0natell0
    I'm tellin ya man take a nice sized bar and jam it in there and just step on the other side to loosen it up
    Oct 2008
    Quote Originally Posted by yunglaosta
    yeah its true tho!!!!
    y not just take the whole thing off the car an fix it.
    southside ATL
    ok, heres the thing. the two bolts that broke they broke in half! so theres no way i can take it out! my uncle said something about tap and drill?
    Oct 2008
    Dude just take a small size chisel and hammer and beat it out
    you can try and ez out, but more than likely wont work.
    Oct 2008
    Just take whole piece off and take it to a shop they will get it out for like $30 bucks or something
    Oct 2008
    IA MEMBER jvillagran2000's Avatar
    EVERYWHERE!!!
    You can also cut the welded nut that is behind the trailing arm and the shock and then use some washers and a grade 8 nut from a harware store.I've had to do this twice,it works.
    southside ATL
    ok so here was the problem.. the bolt was rusted in the bushing so there was no way to take it out. i started out just trying to hammer that shit out. then i started crazy shit like drilling it, and then torching it. yes ppl i said TORCHING it. i had to melt the bushing and pry it out. little did i know it worked.. still need help with the other broken bolt though.. the one that connects the LCA and the spindle.. any1 know?
    heres some pics..
    two different greens.. lol. need a new paint job
    here it is after torching the bushing.. any1 kno how to take the other bolt out?
    sheesh.. that bolt was still hot
    happened to me, had to hacksaw the bolt out and replace the arms
    ATLANTA
    i would take it all of and heat that broken bolt up and hammer it out the same u got the other one out that will to just put a small enough socket over it and hit on the to banng it out make sure the socket will be able to go all the way threw when u bang it out or put it on a press machine and press it out
    RX7
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    jack stands anyone...
