Results 1 to 14 of 14
Thread: NEED HELP!!!!!!!!!
    IA NOOBAROO hollowman's Avatar
    Question NEED HELP!!!!!!!!!
    ok i have a 96 civic with a d16 in it i bought a wrecked 94 integra with a b18 and i wana swap it into my civic what all do i need to complete the swap?????
    Make your signature smaller.
    Thanks,
    -IA MGT
    ATLANTA
    make sure u put that teg wiring harness and the computer i woukld just swap the whole front clip around my opinion
    JDM TYTE AnthonyF's Avatar
    I dont know swaps like the back of my hand, but if you have the entire setup...I think all you need is engine/trans mounts for the desired swap.
    -Ant.
    The Carbon Fibered R6
    You will might as well get a set of avid mounts, and a 00 si rear engine bracket, Then you need to use your engine harness (bring it to me so I can wire it up)... get a obd2a- obd1 conversion harness w/ a chipped p28
    If you want the swap done by someone pro, give us a call 678-567-9384
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    96 is obd2 so you need to do obd2 to obd1 conversion and you need to use the Vtec wiring harness from the GSR and the ecu that came with it,you pretty much have everything you need the mounts are the same in the 96 as your GSR motor if i were you i would take it to mainstream though to make sure its done correctly
    its just a b18b thats not a vtech is it?
    Thanks,
    -IA MGT
    here is the car.....
    Attached Thumbnails Attached Thumbnails -downsized_1211081343-jpg   -downsized_1211081343a-jpg   -downsized_1211081343b-jpg   -downsized_1211081343c-jpg   -downsized_1211081345a-jpg
    Thanks,
    -IA MGT
    i can use some money .. i'll make it work for you !! 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    Oct 2008
    Quote Originally Posted by hollowman
    oh snaps my bad man i read that all wrong my apologies
    Dec 2008
    If you can't spell vtec and you don't know whether the motor is "vtech" or not, you probably don't need to try a swap for the first time.
    Oct 2008
    wth who bumps this kinda thread, all the questions have been answered.
    Oct 2008
    idk good point
