Results 1 to 17 of 17
Thread: 93-97 COROLLA SWAP
    Default 93-97 COROLLA SWAP
    Did anybody do a 4AGE or a 4AGZE in a 93-97 toyota corolla or does anybody know anyone who has done it before?
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by HotHordas7
    Yes... what do you need to know?
    if i get the whole swap
    what other things do i need?
    Morrow 30260
    It depends on what swap you get. What did you have your mind on? I'd recommend not getting the 4agze swap because most of the components aren't even compatible with the 93-97's. And its an extra pain in the ass for not much benefit.
    Morrow 30260
    The silver top and red top swaps are probably the most straight forward. I'd recommend the silver top 20v swap because you can get the whole swap for under $2k. But if you are on a budget, just get a 4age 16v head and mate it to your stock 7afe block (unless you have a 4afe). 7age's are pretty good little setups but if you want a little more, you can always boost it.
    Morrow 30260
    7age is by far the easiest and you get the best of both worlds. Torque of the 1.8 7afe block, and the great flow of the 4age head. You will just need an 86 Porsche 944 timing belt.
    well the 4AFE in the car now is pretty much done
    yea i was thinking on getting the silvertop i read that it has vvt and its selling for around $1200-$1300
    IA Member 90CelicaST's Avatar
    Rome, Ga
    You can get a silvertop engine/trans in Marietta for ~$700. You will still need to source a wiring harness, afm, ecu, etc though.
    ^^ SiRed94 its a noob question butwould i still need mounts to drop the 4age in or does it just drop into the corolla directly along with the stock mounts?
    Morrow 30260
    Well, since you car is an automatic, you will need the mounts that come with the engine (I believe the passenger side mount is the only interchangeable one). The silver top mounts will bolt directly into the chassis and I believe the ae101 mounts bolt in as well along with the 7afe manual mounts. What is your budget for this project? and what are you looking for out of this car HP-wise?
    im not really looking for that much horsepower
    i just want to swap the 4age in and get it running hopefully
    the numbers for the horsepower and the torque to the crank seem to be close with the B16 correct me if iam wrong
    Morrow 30260
    If you are talking about a silver or black top yes. However a regular Blue/Red top 4age... NOOOO....
    Quote Originally Posted by SiRed94
    yea i was reffering to the silvertop
    seems like it would be better than getting the black top
    Rome, Ga
    Some people like the Silvertop better than the Blacktop, and some are vice versa. It would all depend on what you want to do later to the car. The blacktop head flows better, has larger throttles, and is also MAP based instead of AFM like the silvertop. However, the silvertop does have thicker, stronger rods, so it would be safer to turbocharge.
    Quote Originally Posted by 90CelicaST
    thanks for the info and help guys
    yea i was planing on getting the slivertop and dropping it in and hopefully just putting on some bolt ons
    oh yea sorry guys but some more questions can i still use the stock axles or do i need different ones?
    and can i use my stock fuse box or do i need the 4AGE fuse box?
    also will i be able to pass emisions snce it is going to be swapped?
    can anybody help me with these questions
