Results 1 to 15 of 15
Thread: Brake Pedal Sinking To Floor.
    Unknown
    Default Brake Pedal Sinking To Floor.
    Just need some advice.
    No recent brake work done, and the fluid is staying full.
    Any suggestions on what to start with? bleed, master cylinder?
    IF it has just started, its very likely the seals in your master cylinder are going bad. Can you pump the break pedal back to the top? It could also be a leak in the system, seized slide pins on the calipers, or even bad caliper / wheel cylinders.
    You could def start by trying to bleed the system and maybe you'll see cause while you're in there.
    Yep... IDCoconut's Avatar
    Atlanta/Kennesaw
    Also, check to make sure one of your brake lines didn't rupture. Any leak in the system will cause no back pressure. Look and make sure you're not leaving brake fluid spots where you're parked.
    The beach.
    Slave cylinder. Cheap fix prob around $16-30 at a parts store.
    A small leak will lead to the pedal sticking to the floor, and minimal fluid disappearing.
    Quote Originally Posted by Justin.
    Slave cylinder on a brake system? Good luck finding that part.
    The beach.
    I'm an idiot, I wasn't paying attention and was thinking he said clutch.
    ...... amandDA's Avatar
    NE Boonies
    what he said
    LS Resurrection
    Fulton County, Union City
    yeah either u gotta bleed it or its da brake master cylinder.
    Jiggaboo JBthaBoss's Avatar
    Gainesville
    Ya def a leak in tha hydrualic system..
    Do you have drum brakes? could be leaking wheel cylinder
    But most likely an internal master cylinder leak prolly tha primary cup seal
    Unknown
    It comes back up on its own. But I do have to pump it to get pressure back on the disks once it sinks down so far. Its like pushing into a giant sponge.
    Someone told me I could rebuild the mc, cheaper Im sure, but how hard is it to do? Or would it be easier to go to pullapart and replace the whole thing?
    LS Resurrection
    tried bleeding ur brakes yet?
    TR C5 Z06 Whiteboy572's Avatar
    Northside
    Just add some viagra to your brake fluid and it will be up in no time..
    cleveland,tenn
    probally wheel cylinder i thought it was a master cylinder to tell i pulled my drums off...
    ATLANTA
    first try bleeding the whole system all for calipers thats ur best place to start at before u change anything sounds like theres alot of air in the system let me know how it goes
    RX7
    turbos
    master is bad
    or calipers
    I would try another master what kind of car is it?
    TOO BIG
