Thread: Quick Question
    Dunwoody
    Default Quick Question
    Yes I kno wrong section but I need an answer fast. If you download a torrent and it says hdtv will it still play on your computer?if you dont have an hd monitor?
    Thanks In Advance guys
    If you have an extra few hundred dollars that you could spare for another monitor, I'd suggest you go for it. What's going to happen is that your existing monitor will burn up due to running at higher temps due to running at higher frequencies due, again, to running a higher resolution than what your monitor is programmed to run on. A standard definition monitor is set, OEM, to run at 72Hz for a 800x600 display. An HD monitor will require 136Hz. If you run a high resolution video, 136Hz, through a standard resolution monitor, it'll fry the innards faster than a homeless man taking a dollar out of your hands and running down the street to buy a half pint of JD, drinking it and getting back out to the street to beg for his next dollar. What you can do, if you are up to it, is to open the monitor and locate the discombobulator bubulator and on that, you'll find a switch that says, "FLIP THIS SWITCH TO WATCH ALL YOUR FAVORITE MOVIES AND VIDEOS IN A REALLY COOL HIGHER DEFINITION THAN WHAT YOU ARE USED TO TO GET MOVIE AND VIDEO SATISFACTION." That will allow HD versions of Hawaii Five-O and Golden Girls to come through without burning your CRT. Some Dawson's Creek episodes will play ok, but that is strictly trial and error. Hope this helps. Later, QD.
    Dunwoody
    Thanks QD I'll take that into consideration.
    lol you just indirectly owned by him. Your monitor will play it fine. its been in high definition this whole time peaches.
    white power!!!!!! .....1
    NW ATL
    what a nub. yeah itll play fine. carry on.
    Answer is 43
    Answer is 43
    richard petty huh, yep thats the answer
    yes it will play, a standard VGA cable can do 720P
    I have a standard video card (whatever came with my tower) and i use a VGA cable to go to my LCD TV an i watch 720P an 1080P all the time
