Thread: wierd noise from motor from B20Z
    Senior Member mccoy1178's Avatar
    Default wierd noise from motor from B20Z
    Hey guys I wanted to see if anyone has experience this wierd noise from their motors. it goes away in high rpms but around idle to 3k, it sounds like the power steering is low on fluid but I filled up my power steering reservoir and it still makes the noise. I even took off the power steering belt to see to see if my power steering pump is bad and it still makes that noise. The oil level is okay in the motor, the oil light only comes on when it starts off cold and goes off immediately. I kinda have two ideas that might make that noise:
    1) timing belt to tight so it worn out my tensioner OR
    2) oil pump is goin bad
    If u guys can help me on this, Ill be grateful! So honda techs, hook me up!!
    thanx in advance IA
    Mccoy
    Southside
    Hmmmmm does it sound like a pulley that needs to be oiled lol
    id go with number one. my b16 used to make a wierd noise like that but it went away when my cam seals started dumping oil all over the place. lol!!!
    thanx guys! whats the best way to take off the crank pulley bolt? i usualy use my electric dewalt impact but its not working now. lmk thanx
    i once had a waterpump going bad that did the same thing.
    I found it after i torn down my motor. its my ac compressor goin bad i guess. dang after I put 5hrs for nothing. thanx IA
    5HRS?
    I could have found it out in 20mins, I guess that is why I get paid those big bucks!
    Quote Originally Posted by mccoy1178
