Results 1 to 17 of 17
Thread: H22-H23 Injectors.
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Exclamation H22-H23 Injectors.
    whats the difference?? i was thinking of swapping for the h22 injectors. i have both sets and wondering if the h22 are bigger or what?
    Middle, Ga
    *cough* H22 head swap *cough*
    Do it Joe.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Middle Ga.
    i need the wiring harness for it. i have everything else.
    Quote Originally Posted by 93_DA
    i have an engine harness for it. missing 2 or plugs. u can get them off your old harness. $20
    im not sure but i wouldnt think they are any bigger than what your running now.
    edit: they are bigger i had to do some searching
    h23 are 240cc
    h22 are 345cc
    h22 injectors are bigger then h23 injectors i ve been told a few times
    fagNwagN h23bb2's Avatar
    h22A1 USDM= 330CC OBD1
    h22a4 USDM= 280cc OBD2
    h22a JDM= 345cc OBD1&2
    h23a1/3 USDM= 230cc OBD1&2
    f22b JDM= 230cc OBD1
    Hope this helps
    Faggin' Wagon & Queer Kar
    Middle Ga.
    thanks for the help. so i'm gonna put the h22 ones in hopefully this weekend. and we'll see how this goes. my motor should be liking it. haha.
    Middle Ga.
    do you know what plugs they are by any chance?
    Middle Ga.
    whats up Darkstar?? ha.
    Senior Member G.C's Avatar
    Forgot
    So your putting on a h22 injector on a stock h23 motor?? Why would you do that.
    :idb:
    Middle Ga.
    Quote Originally Posted by G.C
    no. the motor isn't stock. that's why i want a bigger injector.
    Southern Speed
    Macon
    whats up, the h22 injector is bigger....BUT it should still flow about the same until you get it tuned or turn up the fuel pressure
    unless you're tuning for it you shouldn't swap injectors unless you're wanting to run rich for some reason.
    the injectors will either be the same or 2 chances to be larger:
    240cc
    280cc
    345cc
    it depends on if the h22 is auto, 5 speed or jdm 5 speed.
    100% agree!!!! your H23 doesnt need the H22 Injectors unless your Boosting NOW, if its a N/A car leave your H23 injectors it will run better then those H22 unless your getting it tuned!
    When I say getting tuned I dont mean in about 6 months from now after you install them I mean NOW before you crank it up!
    240cc
    280cc
    345cc
    Middle, Ga
    I know him. He won't do it and not get it tuned. He'll have everything done the right way the first time.
    "Damn, Its Tyler"
    Middle Ga.
    Quote Originally Posted by Fast-Tech
    why thank you tyler. haha. but i was wanting to run them because my motor has some stuff done and i figured the bigger injector would help it out a little.
    only if you tune for it...sounds like you will though. depending on what you have done to it you may still be ok w/ a stock injector unless you're pushing signifigantly more power.
