Results 1 to 32 of 32
Thread: p28 wont rev after 3k
    Made in BRASIL junior_tm's Avatar
    Brasil
    Default p28 wont rev after 3k
    my ecu is chipped and does not rev past 3k? anyone know why this happens?
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    its in limp mode.
    trying not to kill itself.
    Are you throwing any codes?
    Quote Originally Posted by Homer Simpson
    its in limp mode.
    Sounds like you have a problem my friend!
    Brasil
    i have 02 sensor
    ToTaLMaDNe$$
    Yum-Yum Racing
    nah really u think
    Quote Originally Posted by Innocent-s13
    nah really u think
    JDM TYTE AnthonyF's Avatar
    MAF sensor TYPICALLY..not always.
    -Ant.
    The Carbon Fibered R6
    Senior Member G.C's Avatar
    Forgot
    Did it happen right after you swapped out your ecu?
    :idb:
    did timing jump?
    -Ant.
    Good luck finding a maf.
    Warner robins ,Ga
    -Ant.
    honda with p28 and....MAF?
    Check the chip, make sure it has not come out of the socket, make sure you haven't put it in backwards, make sure someone didn't scramble it w/ the static electricity shock... Make sure all the cells are done...
    Hey, I was just suggesting something. I don't know code names like that. lol.
    -Ant.
    Don Mon SiRed94's Avatar
    Morrow 30260
    IACV plugged in?
    Is chipping the ecu the only thing that has changed since the problem has developed?
    1. check codes
    2. if not codes more than likely speed sensor and launch control (you have an old version of crome that doesn't have throttle position as an option for launch...just speed and rev).
    speed sensor can go bad w/o throwing a code (ie: still puts out acceptable voltage to ecu to not trip cel, but not any speed to ecu). therefore, the ecu thinks it's not moving and results in only reving to the pre-determined launch rev.
    always check codes first...that almost always steers you towards the fix.
    Evergreen Terrace
    we cannot help you if you don't reply to any of our post
    all you said was o2 sensor
    Long Live GM! :^o
    Alpharetta
    Is your car running poorly even though it won't rev past 3000 rpms?
    Any misfires?
    Since a P28 is OBD1, is your check engine light on? If it is, do you know how to pin it to flash the light for DTCs?
    Also, P28s has VTEC a switch, what type of engine do you have?
    General question to assist you finding your issue(s).
    Usually, when you cannot rev past a specfic RPM with a drive-by-cable, you're ECU is either retarding spark or fuel delivery...in essence, as Homer stated, keeping from killing itself.
    I'd start with a fuel pressure test...if pressure is dropping at 3000 rpms, something is telling it to do that.
    Brasil
    sorry i didnt answer some question i work night shift...well im going to check with the guy that has the ecu and i'll bring some more info tomorrow
    thanks to everyone
    ToTaLMaDNe$$
    so is your IACV plugged in? lol
    Atl
    most likely map sensor..what engine harness are u using? is everything plugged into the right spot??
    credibility and reputation
    is it map and iat that the plugs are interchangeable on some hondas? or was it tps?
    Quote Originally Posted by James777
    map and tps.
    iat gets mixed up with a variety of 2 wire sensors:
    pwr steering
    iacv
    iab (burns ecu)
    ect (hard stretch, but i've seen it)
    Yeah I have to because either everyone is a Mechanic so they say or everything thinks they know everything about a Honda/acura lol
    map and tps.
    pwr steering
    iacv
    iab (burns ecu)
    Senior Member Code-Aye's Avatar
    hahaha
    this just happened to me.its your tps
    Morrow 30260
    map and tps.
    pwr steering
    iacv
    iab (burns ecu)
    My favorite is when I get a car that has multiple ones switched up and multiple check engine lights and the customer tells me they have switched out the IACV, MAP, IAT, etc. and they still have the same problem.
    Or when they tell you "I think I have bent valves because my car is skipping but, I'm getting spark on all cylinders." and then they have plug wires swapped up.
    I swear, I could write a 30 page thread on all the dumb shit I have seen over the years.
    1010011010 Atlblkz06's Avatar
    Hell
    TPS sounds like a good bet to me. If the MAP was messed up it wouldnt "stonewall" at 3k. But hey its just a wild guess. Let us know what it was when you do get it fixed!
    L'ville
    haha, as already stated. my old p28 with crome did it too.... damn speed sensor went bad and i had constant launch control
    Nissan by Nature LeX's Avatar
    here
    I had this issue with a different type of car but i thought of all the stuff you guys mentioned.
    Turned out the ECU was getting 10v instead of 12v and that was causing the issue. See how much power your ECU is getting lol!
    72 Datsun 510 goon SR
    83 Datsun Maxima RB
    80 Toyota Cressida 4M
    J.R
    Down South
    Bump for help
    Brasil
    well the guy never called me back so i don know but thanks to everyone that tried to help i spread some love(reps) to yall
    ToTaLMaDNe$$
