Results 1 to 26 of 26
Thread: fresh ls block fs or trade
    1.5T AnTi-PooN's Avatar
    L'villE
    Default fresh ls block fs or trade
    new oem pistons and rods, acl rod bearings, balanced crank, b16 timing belt, obd2 oil pump, new water pump, stage 2 competition clutch, 0 miles... 300 obo or trade for single cam
    Attached Thumbnails Attached Thumbnails -motor-020-jpg   -motor-021-jpg   -motor-022-jpg   -motor-023-jpg   -motor-024-jpg
    L'villE
    oh, new piston rings too
    B16 timing belt?
    L'villE
    it was my ls vtec i couldnt finish
    then you use a GSR timing belt not b16
    L'villE
    actually you're wrong only if you use a gsr head but i had a b16 head. thanks though
    Unknown
    Dec 2008
    what pistons are in there?
    L'villE
    ls
    Unknown
    Dec 2008
    i dont mean to sound like a dick, but u were gonna do ls-v with ls pistons, why? and would u go any lower?
    WRONG if you use the LS waterpump you would use the LS timingbelt!!
    If your using a B16/B17 GSR head you would use the GSR belt!
    B16 timing belt?
    Quote Originally Posted by AnTi-PooN
    I hope you didnt do this build because you don't know nothing
    Although the LS timing belt will fit, upgrading to the more efficient VTEC water pump is a good idea and in doing so, a timing belt from the '94-'01 Integra GS-R is required. The VTEC water pump pulley has 22 teeth as opposed to the 19 found on the LS version, thus requiring the longer belt. The B16A timing belt will not work with either water pump due to the fact that those blocks are about 8mm shorter than the 1.8-liter versions.
    I know my shltt!!!
    God I am good!
    OWNED!
    Augusta Ga
    LOL ^ .. full of ourself EH? ???
    93 sol Si
    95 sol S
    95 sol Si
    Just keeping it real!
    Quote Originally Posted by 1SOL2NV
    Just pisses me off when people try an sell shltt not knowing what they are selling
    Unc crew
    South side union city
    you don't have the ls long block because i need it for my da
    BTW you need to edit your title you dont have a B16 timing belt its a GSR GATES timing belts!!!
    T227 is a B16 an a T247 is a GSR Ls is a T184
    http://www.oreillyauto.com/EW3/Produ...&currentPage=0
    B16 timing belt
    http://www.oreillyauto.com/EW3/Displ...ycleCount=2278
    so let me guess you got this from someone an dont know the truth about it huh>
    Oct 2003
    i dont doubt that everything is new, but when i saw that block i knew whats up with it.....someone slapped it together.....
    yea and you need to clean all the shavings out of the block....i dont want some guy buying it and finding out its fucked after start up... someone honed it but didnt clean the shavings out and used something to deck it with and didnt clean the shavings
    Dayum you got a better EYE then me!! i would buy this, I bet its slapped together too! he didnt even know what Belt is on it!!!
    Quote Originally Posted by Annihilation
    Oct 2003
    nah its cuz i seen it in person, but you can see it in the pics too
    L'villE
    wow, is it a big deal that i thought it was a b16 belt? i just gave the shop the money to get the parts they needed.
    No its you thinking you know the what the hell your talking about! an didnt!
    Not to mention the block has metal shavings all threw out the block! that is verrrry bad is soon for failure!
    L'villE
    i dont know where you see metal shavings
    EM1 Crew Member
    $100 cash
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    Its not the point of which belt you had, its the point you dont know what your selling, you NEVER use a b16 timing in a LSVTEC!!!!! this went to show you dont have a clue what your selling , and Yes You can see the shavings its the shiny little specs in the pics!!
    L'villE
    up
    L'villE
    up
    Sep 2008
    deep in da woods
    when i did my lsvtec i use b16 head also. you have to use gsr belt and gsr water pump to match. cant use the ls belt cuz it too loose and b16 belt is to small..that just my one cent...glws tho..
