Thread: b16 compression?
    about this far.
    Default b16 compression?
    what should the compression of a b16 be? and how much should it drop between the cylinders
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Oct 2008
    this is kinda long, but idk which b16 y0u have so here. all compression specs are bold. g/l. hope this helped. not sure about how much they drop b/t cylinders... not even sure i know what your talking about lol. but gl anyway
    B16A
    Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
    • VTEC
    • Found in:
      • 1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
      • 1988-1991 JDM Honda CRX SiR (EF8)
      • 1988-1991 JDM Honda Civic SiR (EF9)
        • Displacement: 1,595 cc (97.3 cu in)
        • Compression: 10.2:1
        • Rod/stroke ratio: 1.74
        • Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
        • Transmission: S1/J1/Y1/YS1
        • Redline: 8200 rpm
      • 1992-1996 JDM Honda CR-X del Sol SiR (EG2)
      • 1992-2000 JDM Honda Civic SiRII (EG6/EG9/EK4)
        • Compression: 10.4:1
        • Power: 170 hp (130 kW) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
        • Valve Lift: IN 10.7 mm (0.42 in), EX 9.4 mm (0.37 in)
        • Inlet Valve Diamter: 33 by 2 millimetres (1.3 in × 0.079 in)
        • Transmission: S4C/Y21 (Some with LSD)
        • Redline: 8200 rpm
    [edit] B16A1
    • VTEC
    • Found in:
      • 1990-1991 EDM Honda CRX 1.6i-VT (EE8)
      • 1990-1991 EDM Honda Civic 1.6i-VT (EE9)
        • Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
        • Compression: 10.9:1
        • Power: 160 @ 7600 rpm
        • Torque: 109 ft·lbf (148 N·m) @ 7000 rpm
        • Redline: 9500 rpm
        • Transmission: y7
    [edit] B16A2
    Found in:
      • 1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
      • 1992-1997 Honda Civic del Sol EDM VTi (EG)
      • 1999-2000 Honda Civic USDM Si (EM1)
        • Power: 160 hp (118 kW) @ 7800 rpm & 113 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: Y21
    [edit] B16A3
    • VTEC
    • Found in:
      • 1994-1995 Del Sol VTEC
        • Displacement 1,595 cc (97.3 cu in)
        • Transmission: Y21
    [edit] B16A4
    • VTEC
    • Found in:
      • 1996-2000 Honda Civic SiRII (Asian version) (EK4)
        • Power: 145 hp (104 kW) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
        • Transmission: Y21
    [edit] B16A6
    [edit] B16B (Type R)
    • VTEC
    • Found in:
      • 1997-2000 JDM Civic Type R[EK9]
        • Compression: 10.8:1
        • Bore: 81 mm (3.2 in)
        • Stroke: 77.4 mm
        • Rod/Stroke ratio: 1.84:1
        • Rod Length: 142.42 mm (5.607 in)
        • Power: 185 hp (134 kW) @ 8200 rpm & 110 ft·lbf (155 Nm) @ 7500 rpm
        • Redline: 9200 rpm
        • Transmission: S4C With LSD
        • Vtec engagement @ 6,000 rpm
    • Note: This engine uses the same block as the Integra Type R, which is taller than the B16a block, but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16. It is basically a 'Destroked B18C Type R engine'
    Rod/Stroke ratio is at 1.84 and capable for spinning up to 10,000rpm safely.
    North Augusta, SC
    ^^^ He wants to do a compression check.
    I believe it should be around 175-180 from what I've read... but not sure on that one.
    I've also read around 210-230... Try putting in General Tech. Probably get more help there.
    Back to being stock and slow
    about this far.
    what would that be in psi? i heard 220 is good
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    AKA THE BROWN MAN
    Kennesaw, Georgia, United States
    it all veries between health of the rings, pistons, valvles and valve seats basically overall health of the engine i agree with tim anywhere from like 170 up your in good shape anyone correct me if im wrong i just heard about your zc from my brother g/l
    Hamilton, GA
    from 135-225 is good and lower isn't normal. Any big variations from cylinder to cylinder also isn't normal.
