Thread: Which ECU should i use?
    95 teggy for parts DaRussian's Avatar
    Default Which ECU should i use?
    OK i have a 94 del sol and im putting a OBD2 b18b1 swap into it. the engine harness is the obd2 b18b1 harness and it plugs right into the del sol dash harness. which ecu should i use?
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    EF Squad
    Quote Originally Posted by DaRussian
    hmm.. not completely sure but since your car is a 94 i figure that it is a OBD1 and the engine is obd2. So try to make the engine compatible to your car not your car compatible to the engine. What i would do is get a obd1 ls ecu and obd1 dizzy and a ecu jumper. Hope that helps.
    Augusta, GA
    the ecu you need is a P75 or a PR4.
    EF Squad
    Quote Originally Posted by b17a1db2
    yup those are from obd1 ls ecu. As for the PR4 try to get the one that say PR4-A11 because they are the only one that are manual with "OBD1" as for the rest of the PR4 i believe are usually OBD0.
    try an obd1 p75 first...should be plug and play as long as you kept the obd1 harness inside the cabin and all the other wiring is correct under the hood.
    ok thanks guys
    OBDI
    OBDII will not work! run right
    griffin ga
    PO5 PO6 an Get it chipped
